I'm trying to work out how to build a minimal OpenGL application on Raspian.
Once complete, I don't require command line or Window Manager access (outwith the Application itself) however will require HIDs ideally including interfaces for touch.
Really don't have a clue where to start with this... I suppose what I'd like is basically to run directly in X out of the Command Line.
Any suggestions as to how one might achieve this?
Wren
  • 131
Did you consider 2D Game engines/libraries ? Because OpenGL/OpenVG are low-level the added "belt and suspenders" of those libs will make your life much easier - especially considering input handling , too :
http://www.raylib.com/
https://github.com/raysan5/raylib
On the Raspberry Pi technologies incorporating hardware accelleration are preferable (look for OpenGL ES support !) - software rendering might give results which are unbearable.
flakeshake
  • 6,244
  • 35
