Firstly, please excuse if this question seems bit noobish, I just started thinking about getting Raspberry PI, I don't have any experience neither with it nor with ARM platform (well, my phone, but that's something different). I was looking over at this display https://www.raspberrypi.org/products/raspberry-pi-touch-display/ . It's seems like exactly what I would need, but I need to know if I can connect it to regular linux system?
I want to go with gentoo (well, funtoo) on my Raspberry (when I buy it), does anyone here know if this display is supported by standard linux kernel (including the touch screen capabilites)? Or does it require some binary blob drivers (I don't like those)?
graywolf
  • 265
The rpi touch display driver got merged as part of kernel 4.15:
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?id=2f733d6194bd58b26b705698f96b0f0bd9225369
So you'll be glad to know it should work on distros in future that have a kernel version of 4.15+
ericcurtin
  • 121
The Raspberry Pi requires a special out-of-tree kernel period, regardless of whether you want to also use that touchscreen or not. If you are using that kernel, then you should also be able to use the touchscreen.
The good news is:
  1. You are not truly bound to any particular distro just because you need to use a special kernel, although this requires you put in some manual labour. The source for the pi kernel is available, so you can also (cross) compile it yourself (I advise against this unless you have a good reason for it). Inversely, using a particular linux distro, be it gentoo or anything else, generally does not require you use their kernel. However, it may introduce problems particularly if the kernel version falls way behind the one the distro presumes is in play. Which brings us to the second piece of good news...
  2. The people behind the pi kernel do a pretty good job of keeping it reasonably updated, unlike with most platforms in the ARM and Android world (where the "latest" version's vanilla counterpart is several years old). E.g., the latest source in that github link is currently in step with the latest version from kernel.org (4.7.0). The latest pre-compiled kernel, which may or may not be used by various pi-centric distros, is 4.4.12, probably about the same as most mainstream distros. You should be able to use that with funtoo presuming you build everything from source (I seem to recall it's possible to use some pre-compiled packages on gentoo, but if this is the case funtoo probably does not have any for the pi's architecture).
The mainline Linux kernel supports 3D and HDMI output with a fully open source userspace stack. It doesn't yet support the touchscreen display, and you can track status for that at my github.
The Raspberry Pi foundation kernel (which you would be using if you used Gentoo's Raspberry Pi instructions) supports the panel, but it means using a mostly-closed, custom graphics stack that doesn't have many applications ported to it.
Emma Anholt
  • 705
