I have a python program that works fine with Raspberry Pi 3 and with an older Jessie version.
I've tested Jessie 4.4 version and I got the following error:
p1 = request1.registers
AttributeError: 'NoneType' object has no attribute 'registers'
The code is simple:
import pymodbus
import serial
import time
from pymodbus.pdu import ModbusRequest
from pymodbus.client.sync import ModbusSerialClient as ModbusClient
from pymodbus.transaction import ModbusRtuFramer
client1 = ModbusClient(method = "rtu", port="/dev/ttyAMA0",stopbits = 1, bytesize = 8, parity = 'E', baudrate= 115200) connection = client1.connect() request1 = client1.read_holding_registers(0x500B,0x02,unit=1) p1 = request1.registers
print p1
The UART pins are in state ALT0:
  8  | 1 | ALT0 | TxD     | 15  | 14  |
10 | 1 | ALT0 | RxD | 16 | 15 |
The /boot/cmdline.txt file was modified also the serial interface was disabled.
Any idea what is happening?
Itzik
In the Pi3 /dev/ttyAMA0 is connected to Bluetooth.
You should now (in all Pi) use /dev/serial0 which is the device on the GPIO pins.
There may be other issues (not least for some unfathomable reason the Foundation decided to turn serial port off by default).
See How-do-i-make-serial-work-on-the-raspberry-pi3
