It seems to me like there's currently two way to go about this:
I settled for the mongo-nonx86 fork. I installed the dependencies as described in Install Mongodb in Raspberry Pi and tried to build MongoDB using scons. But I get the following error:
generate_buildinfo(["build/buildinfo.cpp"], ['\n#include <string>\n#include <boost/version.hpp>\n\n#include "mongo/util/version.h"\n\nnamespace mongo {\n const char * gitVersion() { return "%(git_version)s"; }\n std::string sysInfo() { return "%(sys_info)s BOOST_LIB_VERSION=" BOOST_LIB_VERSION ; }\n} // namespace mongo\n'])
gcc -o build/linux2/normal/third_party/pcre-8.30/pcre_exec.o -c -fPIC -fno-strict-aliasing -Wstrict-aliasing -ggdb -pthread -Wall -Wsign-compare -Wno-unknown-pragmas -Wcast-align -Winvalid-pch -O3 -DBOOST_ALL_NO_LIB -D_SCONS -DMONGO_EXPOSE_MACROS -DSUPPORT_UTF8 -D_FILE_OFFSET_BITS=64 -DJS_C_STRINGS_ARE_UTF8 -DMONGO_HAVE_HEADER_UNISTD_H -DMONGO_HAVE_EXECINFO_BACKTRACE -DHAVE_SYNC_FETCH_AND_ADD -DALIGNMENT_IMPORTANT -DHAVE_BSWAP32 -DHAVE_BSWAP64 -DHAVE_CONFIG_H -Ibuild/linux2/normal/third_party/boost -Isrc/third_party/boost -Ibuild/linux2/normal/third_party/pcre-8.30 -Isrc/third_party/pcre-8.30 -Ibuild/linux2/normal -Isrc -Ibuild/linux2/normal/mongo -Isrc/mongo src/third_party/pcre-8.30/pcre_exec.c
gcc: internal compiler error: Killed (program cc1)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-4.6/README.Bugs> for instructions.
scons: *** [build/linux2/normal/third_party/pcre-8.30/pcre_exec.o] Error 4
scons: building terminated because of errors.
Compiling mongopi will stop at the exact same file with the same error message.
In the meanwhile, I realized that my system was dramatically outdated. But even upgrading to the latest versions didn't resolve the problem. At this point, I'm assuming that it is indeed an issue with free memory. Given that I only have an early 256 MB model.
