Hope someone can help me get started. As I realize MCP3008 200 k samples per second. This is what I want because the thing I want to measure only is a few hundred microseconds. But will the Raspberry Pi manage to take all the samples in from the ADC? Most of the samples I have to sort out, and then I have to calculate a mean value of samples is left. I've read around a bit about SPI and it is well explained with code as it is called bitbanging, this is maybe not quite good as it is quite slow. I'm no expert in programming but has been involved in some c + + programming.
For your type of usage, I would not use the bit-bang SPI. The RPi also has a hardware SPI bus, this can be used up to a clock rate for the SPI bus of 20Mhz. If you just want a couple of microseconds of data from the ADC and do some calculations with that, that will not be a problem at all. Please read the discussion that is going on on this question: RPi as a Sound Level Meter?
One user (scruss) of this site suggested this link which explains the hardware SPI bus on the RPi and how to use it.
The datasheet of the ADC can help you further on how to enable and disable and control the ADC itself, there is also a link to that document in the references question.
Update
As scruss pointed out correctly, you'll need to supply 5V to the ADC to get the amount of samples per second. This implies that you will need to convert the logic levels of the bus from and to 5V for the ADC. An example of how this can be done is here. But there are more ways to get this done.
