11
Is there a well-known package I should install for C++ Development Tools?
What do I type at the command-line after sudo apt-get install?
Ideally, I want the same tools that were installed with "MinGW" on my Windows computer.
imulsion
  • 771
To install development tools on raspbian :
sudo apt-get install build-essential
mpromonet
  • 1,124
  • 38
Henry Todd
  • 161
That may depend on your distro, but if you are using raspbian, the stock gcc includes g++, here's the version info:
me@RPiĀ» gcc -v
Using built-in specs.
--enable-languages=c,c++,fortran,objc,obj-c++
So apt-get install gcc should work if it isn't already there.
Most distros will build gcc with C++ support, so this should be true for them too. The easy way to check is to install gcc then try g++ -v.
FYI, GCC is the "Gnu Compiler Collection" used by MinGW; gcc is the C compiler, g++ is C++.
To compile C++ code you'll also need the stdc++ header files (#includes) from the "libstdc++ dev package". There is more than one available for raspbian because there are 4 slightly different versions of libstdc++ available. The one which appears to be the default against which (presumably) all or most binaries in the distro are built looks to me to be 6-4.6. Check with:
dpkg -l | grep ++
That's what is currently installed. If you don't see any libstdc++ listed, then just pick one from what's available (apt-cache search libstdc++). You can have them all installed at the same time, although the system will tend to use only one (there is a symlink based on major version in /lib to one of the .so's). So:
apt-get install libstdc++6-4.6-dev
That should (I think) include the base library as a prereq, in which case that and gcc and its prereqs should cover everything. If it doesn't, just install libstdc++6-4.6. Library packages in most linux distros come in two parts, the runtime, and the headers in a separate -dev package for compiling using the API.
Bex
  • 2,929
  • 26
  • 34
best app for C++ can be found by either searching Code Blocks of going on apps and looking down till you see it and its actually quite near the top. I used this app on my PC before i discovered it on my raspberry pi and has syntax highlighting and everything.
