I have bought the NoIr cam for the Raspberry Pi. I stream the video of that camera to my other Ubuntu server using VLC:
cvlc v4l2:///dev/video0 --v4l2-width 1920 --v4l2-height 1080 --v4l2-chroma h264 --sout '#standard{access=http,mux=ts,dst=0.0.0.0:12345}'
The problem with this is that when I cancel the stream using ^C, the stream can not be restarted.
First stream (working):
raspberrypi :: ~/scripts % sudo modprobe bcm2835-v4l2
raspberrypi :: ~/scripts % cvlc v4l2:///dev/video0 --v4l2-width 1920 -- v4l2-height 1080 --v4l2-chroma h264 --sout '#standard{access=http,mux=ts,dst=0.0.0.0:12345}'
VLC media player 2.2.1 Terry Pratchett (Weatherwax) (revision 2.2.1-0-ga425c42)
[0062b780] pulse audio output error: PulseAudio server connection failure: Connection refused
[00627258] core interface error: no suitable interface module
[0058df10] core libvlc error: interface "globalhotkeys,none" initialization failed
[00627258] dbus interface error: Failed to connect to the D-Bus session daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
[0058df10] core libvlc error: interface "dbus,none" initialization failed
[00627258] dummy interface: using the dummy interface module...
[b3d04fc0] access_output_http access out: Consider passing --http-host=IP on the command line instead.
When I cancel after the above command and try again, I get the following output:
Failing attempt
^C%
raspberrypi :: ~/scripts cvlc v4l2:///dev/video0 --v4l2-width 1920 --v4l2-height 1080 --v4l2-chroma h264 --sout '#standard{access=http,mux=ts,dst=0.0.0.0:12345}' 1 ↵
[016f0780] pulse audio output error: PulseAudio server connection failure: Connection refused
[016ec258] core interface error: no suitable interface module
[01652f10] core libvlc error: interface "globalhotkeys,none" initialization failed
[016ec258] dbus interface error: Failed to connect to the D-Bus session daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
[01652f10] core libvlc error: interface "dbus,none" initialization failed
[016ec258] dummy interface: using the dummy interface module...
libv4l2: error turning on stream: Operation not permitted
[b3d09b78] v4l2 demux error: cannot start streaming: Operation not permitted
[b3d09b78] v4l2 demux error: not a radio tuner device
So far I have checked, using htop, that no VLC process remains and I can't seem to find one. To me it seems like the resource (the video) is not being released by canceling the previous stream.
Any tips?
