11
I have found this thread on how to switch boot default behaviour on Raspbian Jessie from boot to command-line to boot to GUI and back.
Booting to command-line:
sudo systemctl set-default multi-user.target
Booting to GUI:
sudo systemctl set-default graphical.target
However, the same thread also indicates how to disable autologin, and while I got this to work for booting to command-line (and switching it back to autologin), booting to GUI always autologins. Are these commands incorrect?
Manual login:
ln -fs /lib/systemd/system/getty@.service /etc/systemd/system/getty.target.wants/getty@tty1.service
Autologin:
ln -fs /etc/systemd/system/autologin@.service /etc/systemd/system/getty.target.wants/getty@tty1.service
tlhIngan
  • 3,372
  • 33
This can easily be done with raspi-config.
  1. Run the command sudo raspi-config
  2. Select Boot Options
  3. Choose Desktop
  4. Exit the prompt and restart the RPi
Edit:
To address you wanting to do this from the command line for a bash script, I suggest we look at the actual source of raspi-config (which is written in bash).
if [ $SYSTEMD -eq 1 ]; then
else
  [ -e /etc/init.d/lightdm ] && update-rc.d lightdm disable 2
  sed /etc/inittab -i -e "s/1:2345:respawn:\/sbin\/getty --noclear 38400 tty1/1:2345:respawn:\/bin\/login -f pi tty1 <\/d$
fi
Jacobm001
  • 11,904
  • 47
  • 58
