I was looking in /var/log/syslog for other reasons and i saw that it said:
May 23 06:25:54 raspberrypi rsyslogd0: action 'action 17' resumed (module 'builtin:ompipe') [try http://www.rsyslog.com/e/0 ]
then on the line just below it said:
May 23 06:25:54 raspberrypi rsyslogd-2359: action 'action 17' resumed (module 'builtin:ompipe') [try http://www.rsyslog.com/e/2359 ]
what is the difference between these two and what do they mean?
I have searched for "action 17 on raspbian" and other things like that but found no helpful results.
sir_ian
  • 980
  • 38
An answer can be found here
I will simply cite from source 1:
This is a bug in the rsyslog config from debian (which raspbian is based off).
It's something you can ignore, its just saying that the buffer (/dev/xconsole) used by some (rare) applications is full.
You can clear that buffer by reading from it (cat /dev/xconsole), but then it'll fill up again over time. You can also remove a bit of configuration to stop that buffer being used.
As root edit the /etc/rsyslog.conf file and remove the following lines from the bottom of the file.
daemon.*;mail.*;\
        news.err;\
        *.=debug;*.=info;\
        *.=notice;*.=warn       |/dev/xconsole
(you could also comment them out by putting a # at the start of the lines)
You can then restart the rsyslog service with CODE:
sudo systemctl restart rsyslog.service
or reboot.
Here is my solution for the Action 17 error message. Edit the file.
sudo vi /etc/rsyslog.conf
Go to the end of the file and split the lines as follows.
daemon.*; \
mail.*;\
news.err;\
*.=debug; \
*.=info;\
*.=notice; \
(control c) :wq! - to exit if using vi !!!!
Restart the raspberry pi. This allows rsyslogd to function properly.
Piotr Kula
  • 17,336
  • 66
  • 105
