I set up Openwrt CHAOS CALMER on my Raspberry Pi 2. I plugged in a WiFi dongle that uses the RTL8192CU chipset (Link). I have been looking online and trying to install different packages to help correct the issue. When I plug in the dongle and boot Raspbian, it detects the dongle. After that, when I run ifconfig, the dongle comes up as wlan0.
But, when I look for wlan0 in Openwrt, it doesn't show up.
root@OpenWrt:~# wifi up
'radio2' is disabled
root@OpenWrt:~# wifi status
"radio0": {
"up": false,
"pending": false,
"autostart": false,
"disabled": false,
"config": {
"channel": "36",
"hwmode": "11a",
"path": "virtual\/mac80211_hwsim\/hwsim0",
"htmode": "VHT80"
"interfaces": [
"section": "@wifi-iface[0]",
"config": {
"mode": "ap",
"ssid": "OpenWrt",
"encryption": "none",
"network": [
"lan"
"mode": "ap"
"radio1": {
"up": false,
"pending": false,
"autostart": false,
"disabled": false,
"config": {
"channel": "36",
"hwmode": "11a",
"path": "virtual\/mac80211_hwsim\/hwsim1",
"htmode": "VHT80"
"interfaces": [
"section": "@wifi-iface[1]",
"config": {
"mode": "ap",
"ssid": "OpenWrt",
"network": [
"lan"
"mode": "ap"
"radio2": {
"up": false,
"pending": false,
"autostart": true,
"disabled": true,
"config": {
"channel": "11",
"hwmode": "11g",
"path": "platform\/bcm2708_usb\/usb1\/1-1\/1-1.4\/1-1.4:1.0",
"htmode": "HT20",
"disabled": true
"interfaces": [
"section": "@wifi-iface[2]",
"config": {
"mode": "ap",
"ssid": "OpenWrt",
"network": [
"lan"
"mode": "ap"
root@OpenWrt:~# ifconfig
br-lan Link encap:Ethernet HWaddr B8:27:EB:25:49:B8
inet addr:192.168.1.90 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::ba27:ebff:fe25:49b8/64 Scope:Link
inet6 addr: fdad:28dc:e168::1/60 Scope:Global
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:22719 errors:0 dropped:0 overruns:0 frame:0
TX packets:14628 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:2508036 (2.3 MiB) TX bytes:3103130 (2.9 MiB)
eth0 Link encap:Ethernet HWaddr B8:27:EB:25:49:B8
RX packets:27049 errors:0 dropped:0 overruns:0 frame:0
TX packets:14403 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:3674587 (3.5 MiB) TX bytes:3243136 (3.0 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:610 errors:0 dropped:0 overruns:0 frame:0
TX packets:610 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:58143 (56.7 KiB) TX bytes:58143 (56.7 KiB)
