I am setting up a demo lab where I build a baby Openstack data center using MaaS and Juju with LXD hypervisors running ZFS. Here is my setup:
  • Macbook Pro i7, 16GB RAM
  • VMWare Fusion VM(s) running Ubuntu 16.04 with LXD
  • 4 Raspberry Pi's, version 3
  • 10/100 Ethernet switch
  • Thunderbolt Ethernet for bridging the Fusion network to the physical switch.
I would like to boot the Ubuntu 16.04 ARM64 image to the Pi's using MaaS, but am having a hard time finding instructions related to enabling PXE on the Pi. Does anyone know where I can find something more substantial than "it's supported" that I can reference?
Darth Vader
  • 4,218
  • 47
  • 70
spyderdyne
  • 151
Documentation is now available to enable network boot from the wired network connection for the Raspberry Pi3.
Program USB Boot Mode
First, prepare the /boot directory with the latest boot files:
sudo apt-get update && sudo apt-get upgrade
Now, enable USB boot mode with the following command:
echo program_usb_boot_mode=1 | sudo tee -a /boot/config.txt
This adds program_usb_boot_mode=1 to the end of /boot/config.txt. Reboot the Raspberry Pi with sudo reboot. Once the client Raspberry Pi has rebooted, check that the OTP has been programmed with:
$ vcgencmd otp_dump | grep 17: 17:3020000a
Ensure the output 0x3020000a is correct.
The client configuration is almost done. The final thing to do is to remove the program_usb_boot_mode line from config.txt (make sure there is no blank line at the end). You can do this with sudo nano /boot/config.txt, for example.
Finally, shut the client Raspberry Pi down with sudo poweroff.
Source: Link
Glorfindel
  • 620
Radu Herinean
you don't PXE boot any Raspberry Pi except the Pi3 and Pi4
For Raspberry Pi 1, 2 and their variants, the short answer is that it is not supported.
but you can, sort of
The "firmware" on the RasPi GPU (yes it's (part of) the gpu that actually boots first and proceeds to bootstrap the cpu) will need to load its blobs from an inserted SD card - there's no way around this so you absolutely need an SD card inserted with a FAT32 partition and the right files on it.
After that, it's just software so sky's the limit. You can technically have a boot loader on the SD that proceeds to get the linux kernel and initial ramdisk with PXE - I don't know if such a thing actually exists but it is definitely possible to do.
If there is not a PXE enabled boatloader, you can prepare an SD card with just the binary blobs, the kernel and the ramdisk. Technically speaking you are not PXE booting, but you should be able to boot the kernel+ramdisk locally and then NFS-mount the root filesystem from a remote server. The SD card would need only a couple of megabytes of space and would be used strictly read-only, so I'd expect it to achieve a really long working life.
you can network boot the Pi3 and Pi4
The Raspberry Pi 3 introduced some new boot modes, including PXE over the on-board ethernet port. See PI 3 BOOTING PART II: ETHERNET for details.
tomodachi
  • 115
Luke404
  • 229
The capability for USB/PXE boot is thought to be there and is said to work.
USB and PXE network boot
Even with the chip designed and taped out in March of last year, the Foundation had some final input for Broadcom in order to add two new features: direct USB mass storage and PXE network boot capabilities. “Gordon rewrote the boot ROM for the chip and then provided an updated boot ROM to Broadcom, saying ‘shove this in the chip, it’ll work’,” Eben laughs. “And it does!
See https://www.raspberrypi.org/magpi/pi-3-interview/
However I know of no evidence that any production Pis have had the new ROM software installed. I don't see how this could be retrofitted to existing Pis.
EDITED TO ADD
The current situation was said to be some form of USB boot by the end of April and PXE boot by the end of May.
Listen to http://thepipodcast.com/media/ThePiPodcast022.mp3 from minute 25.
Given that the end of April milestone has passed I'd take any dates with a pinch of salt.
joan
  • 71,852
  • 76
  • 108
