Using the Raspberry Pi 3
My Linux
It's a Yocto image with Sato desktop
root@raspberrypi3:~# lsb_release -a
LSB Version:    core-4.1-noarch:core-4.1-arm
Distributor ID: poky
Description:    Poky (Yocto Project Reference Distro) 1.8.1
Release:    1.8.1
Codename:   fido
root@raspberrypi3:~# uname -a
Linux raspberrypi3 4.1.18 #1 SMP Thu Mar 17 10:26:07 CET 2016 armv7l GNU/Linux
What I have done so far
Created 10-monitors.conf file
root@raspberrypi3:/etc/X11/xorg.conf.d# ls -al
drwxr-xr-x    2 root     root          1024 Mar 19 04:59 .
drwxr-xr-x    7 root     root          1024 Oct 19 15:15 ..
-rw-r--r--    1 root     root          1099 Mar 17 08:31 10-evdev.conf
-rw-r--r--    1 root     root           330 Mar 19 04:59 10-monitors.conf
and added these
Section "Monitor"
    Identifier "Monitor0"
    Option "DPMS" "false"
EndSection
Section "ServerLayout"
    Identifier "ServerLayout0"
    Option "StandbyTime" "0"
    Option "SuspendTime" "0"
    Option "OffTime"     "0"
    Option "BlankTime"   "0"
EndSection
Inspired by this archlinux documentation
Will this work? How do I check that these were taken into effect?
Update
xset -q
xset:  unable to open display ""
zabumba
  • 257
First, you need an output from xset -q. If you setup the Pie from ssh, add DISPLAY=:0 to every command that gives you unable to open display message:
DISPLAY=:0 xset -q
Then run
xset -dpms
xset s off
xset s noblank
xset s noexpose
xset s 0 0
or from ssh
DISPLAY=:0 xset -dpms
DISPLAY=:0 xset s off
DISPLAY=:0 xset s noblank
DISPLAY=:0 xset s noexpose
DISPLAY=:0 xset s 0 0
Keep your eye on Screen Saver and DPMS sections of xset -q output after each command. This way define what helps you to keep screen on.
Then add these commands to ~/.xinitrc where they will be executed every time the Xorg server starts.
Mikolasan
  • 131
