I have three libraries (is library the right word?) that I'm using in my Python code:
  • An Adafruit NeoPixels library, which comes from the rpi_281x library to control them via PWM, on GPIO pin 18.
  • One to control WS2801 Adafruit pixels (which I call "PaleoPixels" in my code. This uses SPI to write to the chips, using MOSI (GPIO pin 10) and SCLK (GPIO pin 11) pins for control.
  • A "SuperPixel" library to gang together multiple strands of both types into a super-strand, and control them with a single command set.
All of this works quite well on its own, and I can run animations at a pretty decent frame rate, if I just run a script from the terminal.
My problem seems to start when I try to use GPIO interrupts to detect button presses to trigger different LED patterns. The NeoPixels continue to work, but the SPI-driven PaleoPixels just go haywire. After a little trial and error, it seems to be related to listening for the GPIO interrupts that's somehow conflicting with the PaleoPixel control signal.
I don't have a logic analyzer, so I'm not sure exactly what's going wrong yet, but is there anything in my control script that's an obvious conflict with the SPI ontrol of the PaleoPixels, or something else I'm doing wrong with how I'm handling interrupts?
import RPi.GPIO as GPIO
import neopixel
import paleopixel
from superpixel import *
GPIO.setmode(GPIO.BCM)
GPIO.setup(23, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(24, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(25, GPIO.IN, pull_up_down=GPIO.PUD_UP)
# Set up the strand
# My LED strip configurations (for test):
NEOPIXEL_COUNT   = 244   # Number of NeoPixels in the strand
NEOPIXEL_PIN     = 18    # GPIO pin connected to the pixels (must support PWM!)
PALEOPIXEL_COUNT = 50    # Number of PaleoPixels in the strand
# Create pixel strands with appropriate configuration.
strand1 = neopixel.Adafruit_NeoPixel(NEOPIXEL_COUNT, NEOPIXEL_PIN)
strand2 = paleopixel.PaleoPixel(PALEOPIXEL_COUNT)
# Combine them into one SuperPixel strand
strand = SuperPixel(strand1, strand2)
# Intialize the SuperPixel strand (must be called once, before other
# functions, if the SuperPixel strand contains any NeoPixel sub-strands)
strand.begin()
# FIXME: Setting up these GPIO interrupts seems to be killing the control
#        stream to the PaleoPixels
# Set up our GPIO callbacks
def button_white(channel):
    print("button_white")
    colorAll(strand, Color(255, 0, 0))  # Set all LEDs to Red
def button_amber(channel):
    print("button_amber")
    colorAll(strand, Color(0, 255, 0))  # Set all LEDs to Green
def button_red(channel):
    print("button_red")
    colorAll(strand, Color(0, 0, 255))  # Set all LEDs to Blue
# Physical button interrupts
GPIO.add_event_detect(23, GPIO.FALLING, callback=button_white, bouncetime=300)
GPIO.add_event_detect(24, GPIO.FALLING, callback=button_amber, bouncetime=300)
GPIO.add_event_detect(25, GPIO.FALLING, callback=button_red, bouncetime=300)
# Idle loop
while 1:
    # Should I be doing something else here?
    pass
GPIO.cleanup()
swizzlevixen
  • 313
You may have identified the problem with a comment in your code.
# Idle loop
while 1:
    pass
The while loop will be using up all the spare CPU in the "busy spin".
The only purpose of the loop is to keep the script running so that the callbacks can do their work.
Try changing the loop to:
import time
# Idle loop
while 1:
    time.sleep(1)
That will drop the loop CPU usage from almost 100% to almost 0%.
joan
  • 71,852
  • 76
  • 108
