Let's assume that I am dropped into a room with a Raspberry Pi running either Debian or Raspbian. How do I find out if it has hard float support or if it is just using soft float?
Asked
Active
Viewed 3.5k times
55
Check for the existence of the directory:
/lib/arm-linux-gnueabihf
the soft-float version do not have this directory, they have:
instead, or you can list the packages installed using:
dpkg -l
and see the platform in the third column (all/armhf/armel)
ikku
- 4,544
- 1
- 26
- 28
24
The accepted answer is correct, but a really simple method is:
dpkg --print-architecture
If your system is using a hard float architecture, you will then see:
armhf
ARM Hard Float. :-)
Chris
- 350
- 2
- 6
Issue the command:
readelf -A $(which dpkg)
On a hard-float (hf) system, you will see this as part of the output:
Tag_ABI_VFP_args: VFP registers
Will
- 210
- 2
- 5
