12
I believe my question is different from the suggested duplicate in that the other questioner never had access to the internet over Wifi, whereas I had access to Wifi without any problems for one week but no longer do. Along with a fix, I am asking to debug it to see what happened. KDMs answer also permitted me to reactivate the WiFi without restarting; whereas the other answer required a firmware update and a restart.
I hooked up my new Raspberry Pi 3 and the Wifi was very easy to set up. However, about 1 week after this I could not SSH into the pi. My router's UI didn't show the RPI3 registered any more over Wifi.
I plugged in an Ethernet cable and my Pi immediately registered with my router. I SSH'd into it and attached to my session of screen and saw that my application was still running. This means the Pi never turned off or restarted -- only the Wifi stopped working. It has been about one more week and the Wifi has never come back online by itself. My RPi2, cellphone, laptop, etc. still have access to WiFi.
Aside from doing a restart, how do I fix this? How do I debug this?
Solution
Update: @KDM's solution, which use used on RP1/RP2 for wifi dongle problems, also worked for me (I believe this proves that this question is not a duplicate):
sudo ifdown wlan0
sudo ifup wlan0
However, I am concerned that the WiFi stopped working in the first place. I don't want to have to plug in an ethernet cable and issue these two commands every week. I have two RPI 1s with two different WiFi dongles. One of them never had any issues at all, while the other one needed to be restarted every so often. I'm worried that there could be something wrong with the RPI3's in built WiFi.
I have the latest version of Raspbian Lite, version March 2016.
Issuing sudo apt-get dist-upgrade shows that the following packages will be upgraded:
apt apt-utils gnupg gpgv initramfs-tools libapt-inst1.5 libapt-pkg4.12
libc-bin libc-dev-bin libc6 libc6-dbg libc6-dev libhogweed2 libnettle4
libpcre3 libsystemd0 libtalloc2 libudev1 libwbclient0 locales
multiarch-support openssh-client openssh-server openssh-sftp-server
raspberrypi-sys-mods raspi-config samba-common ssh systemd systemd-sysv
tzdata udev
I can sudo iwlist wlan0 scan > scan.log and find my SSID in the list. I can post this if it would be helpful.
Running ifconfig shows the wlan0.
I am using the default /etc/network/interfaces file that comes loaded on Raspbian Jesse for RPI3:
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
allow-hotplug wlan1
iface wlan1 inet manual
Matthew Moisen
  • 745
  • 25
5 Answers5
(Edit: good point, Matthew Moisen)
I had a problem with my RPi2 (with an external USB WiFi dongle). Ultimately I found a replacement adapter, but my solution (unfortunately, as you've discovered, you'll need a hardwired connection) to resetting it without rebooting the RPi was to restart the WLAN interface:
sudo ifdown wlan0
sudo ifup wlan0
I've subsequently swapped out my dongle for one which didn't originate in Hong Kong and I've not had any bother with it since ... even though it lives in my airing cupboard, which is not the favoured environment for computing equipment!
Edited again:
The other thing, I've just remembered. Try rebooting your router. I've never fallen foul of this with the Pi, but my android phone loses WiFi every other week and will not re-connect (even after a battery yank). There is an upper limit on the number DHCP addresses which my router can "remember" issuing. My suspicion is that if 10 devices all have a 7 day lease to run, the 11th doesn't get issued an IP. Rebooting seems to clear the leases. Suck it and see.
KDM
  • 718
If the wlan0 works for a period of time after booting and then goes away is it possible it is related to localization settings as mentioned in this post. I set my location for WiFi and have not had it dropped.
1JJ1
Running Wicd might get it working without any reboot, but I've never had luck making the settings permanent. Using an /etc/network/interfaces file is a good simple permanent solution that will apply settings every time you boot, OTOH it only works when you're booting. So wicd for now and study the man page for interfaces. If your first version of interfaces doesn't work you can always use wicd each boot until you get it right.
It's just a text file, mine looks like this (for wired and wifi):
    # new interfaces file 4/23/2016
    source /etc/network/interfaces.d/*
    auto lo
    auto wlan0
    iface wlan0 inet dhcp
      wireless-essid Moto_lte
      allow-hotplug wlan0
    auto eth0
    iface eth0 inet static
      address 192.168.0.16
      netmask 255.255.255.0
      network 192.168.0.0
      broadcast 192.168.0.255
You should also look at man wpa_supplicant. Oh, and you can run wicd (or most things) by typing sudo wicd into a terminal window if you can't find it in the menus. If you get an error that it's not found then do
     sudo apt-get install wicd
assuming you can connect somehow. It is possible to get it on another machine, put it on a USB stick and load it but I won't go into that.
Alan Corey
  • 201
It sounds you didn't change interfaces file but anyway, make sure your /etc/network/interfaces file has no manual configurations or you should do manual configuration for all interfaces (eth0, wlan0 and lo). For automatic configuration leave it with original code:
Hey You will need to replace the bcrm folder of any of your WiFi working Operating Systems to the Operating System in which WiFi doesn't work. bcrm folder is located in "/lib/firmware/". I am sure that this helps to resolve all networking issues.
Video Tutorial : https://www.youtube.com/watch?v=xVTgcXE8rrY
