I have a DSB18B20 temperature sensor and would like to log the readings in a csv file.
I have a script templog.py that stores the readings in a file. The file starts with #!/usr/bin/python That works.
When I run /usr/bin/python /home/pi/mypath/templog.py the script runs as well.
I then tried to add a crontab for that.
sudo chmod -x templog.py
I was in the correct path for that, therefore no absolute path given.
sudo crontab -e
* * * * * /home/pi/mypath/templog.py
/1 * * * * /home/pi/mypath/templog.py
*/1 * * * * /home/pi/mypath/templog.py
/1 * * * * /usr/bin/python /home/pi/mypath/templog.py
/1 * * * * sudo /usr/bin/python /home/pi/mypath/templog.py
Neither of this works.
idkfa
  • 123
Make sure the script is executable.
chmod +x /home/pi/mypath/templog.py
To run every minute the correct crontab entry will then be
If you use the root crontab make sure root has permission to write to your log file.
It would probably be best to use your ordinary crontab.
crontab -e rather than sudo crontab -e.
joan
  • 71,852
  • 76
  • 108
