I use PuTTY and a Wi-Fi dongle to SSH into my Pi. It ALWAYS times out on the first attempt and then when I close PuTTY and re-open it, I can SSH into the Pi.
Any ideas why this is happening?
EDIT:
iwconfig:
wlan0     IEEE 802.11bgn  ESSID:"Tom"  Nickname:"<WIFI@REALTEK>"
          Mode:Managed  Frequency:2.442 GHz  Access Point: 30:46:9A:A2:59:D6
          Bit Rate:72.2 Mb/s   Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:****-****-****-****-****-****-****-****   Security mode:open
          Power Management:off
          Link Quality=100/100  Signal level=85/100  Noise level=0/100
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
lo        no wireless extensions.
eth0      no wireless extensions.
lsusb:
Bus 001 Device 004: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
user2570937
  • 133
Probably you got power saving mode enabled in your WiFi dongle.
You can check it in sudo iwconfig and turn it off: sudo iwconfig wlan0 power off , where wlan0 is your wifi card name in iwconfig list.
If it doesn't help tell us more about your WiFi dongle. Post iwconfig and lsusb by editing your post.
@Edit: Here was similar issue and this post helped:
Huczu
  • 1,251
Pi4,I use this command:
 sudo iw dev wlan0 set power_save off
menxin
  • 126
