As stated on the official Golang site, there is no binary distribution for ARM yet.
I'll have to compile GO from source, and it might not be straightforward, and require a few tries. Compilation itself is more likely to succeed if I have a lot of RAM and plenty of HDD space. Also I don't want to mess up with my tiny system during the several try-error compilation attempts.
Is it possible for me to use my desktop PC with Ubuntu to make the compilation, with all the flags indicating that the target platform is my ARM-based Raspberry Pi?
Thanks in advance, any experience feedback will be welcome.
Deleplace
  • 123
I would try it on the pi itself, it seems simpler. The tutorial page you point at lists only gcc and mercurial as dependencies, these are simple and safe to install. Further, you can avoid mercurial if you just download the source as a tarball.
On the raspberry forum there is a useful thread about installing go on the Pi. In particular: you have to set the environment variable GOARM=5 before compiling, to choose the correct ARM instruction set.
I just tested building go on my 256 MB Pi with raspbian.
sudo apt-get install gcc libc6-dev mercurial
mkdir src
cd src
hg clone -u release https://code.google.com/p/go #takes several minutes
cd go/src
GOARM=5 ./make.bash
GOARM=5 chooses an appropriate instruction set make.bash just compiles, while all.bash runs some tests as well.
Compilation succeeded, and I was able to run the hello.go example.
GOARM=5 ~/src/go/bin/go run hello.go
note that the GOARM variable again needed to be set. Put it in .bashrc or some appropriate place to set it permanently.
Cross-compilation is in general possible, though. These instructions for cross-compiling the kernel, might help.
EDIT: reading further in the forum thread, I saw that there is a golang package in the raspbian repositories. You could try installing it. According to the forum, you still need the environment variable GOARM=5 when running.
Frepa
  • 2,261
I just set-up a gcc/++ cross-compiler targeting the pi (hard float armv6, etc) on a linux x86-64 desktop using crosstool-ng, and was pretty impressed with how user friendly the crosstool is (the interface is exactly like the kernel source's make menuconfig, including help for all options and a / search). It even downloads all the necessary tarballs for you.
I've been a C programmer for years but the idea of configuring all that manually made me want to retch, so hooray crosstool-ng.
The compiler compiles but I won't be able to test any executables on the pi until later today or tomorrow, at which point I'll update this post. However, seeing as how I found it recommended somewhere by a pi-head, I assume this should work.
[Later...] It does work, but here's the rub: WRT non-trivial stuff involving a lot of infrastructure, autotools configure, pkg-config, etc -- pure headache. I would only go that route if I had no other choice at all.
My advice would be to build GO from source on your desktop, for your desktop, without installing, just so you can check how the configure options etc. work out. Once you have that straight, do it on the pi and leave it alone for however long it takes.
