I've got a more common question. I come from bare metal microcontroller development - there we usually avoid flash write access for several reasons. one is to avoid damage of the flash memory because of too many erase/write cycles.
the raspberry is running from a sd card, which is also flash memory.
So i ask myself whats with the linux system running on a embedded system and the "everything is a file" philosophy.
Is the system writing every time physically to the flash (e.g. for logging) or is there a driver layer which collects requests and writes bigger blocks delayed to the physical semiconductor?
When i write scripts for the embedded system, should I avoid redirection like foo > tmp.file temporary file writes when the script is running every minute and data could be also held in RAM?
i am curious whats your expert opinion about it...
twooBeers
  • 123
Your understanding of the problem seems to underestimate the write life of the given flash memory.
This is true, but only kind of. The "everything is a file" philosophy doesn't mean it's a legitimate (as in physical) file. /proc/cpuinfo, for example, is a "file", but it doesn't reside anywhere on the disk. It's a virtual file. Anything you write to or read from that "file" is coming straight from memory.
All modern operating systems have a buffer that tries to make writing more efficient. So, in some sense, it will try to block the data a little, but the RPi will log just like any other desktop/server OS.
When I write scripts for the embedded system, should I avoid redirection like foo > tmp.file temporary file writes when the script is running every minute and data could be also held in RAM?
It's not really necessary to avoid the temporary writes. I would just log directly to the file. I find your design choice a little odd, but it's not wrong or ill advised per say.
Jacobm001
  • 11,904
  • 47
  • 58
