I was following this tutorial: http://webiopi.trouch.com/Tutorial_Serial.html so I can make serial communication using the On-board serial UART
I couldn't find the file /etc/inittab, I skipped that step because I read that this file doesn't exist in Jessie.
Then I edited /boot/cmdline.txt and it says that I need to remove references to ttyAMA0.
This is what I find in that file:
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Should I erase the serial0? I got really confused by this and I'm not sure what to do.
Luz A
  • 57
Firstly you should NOT edit /boot/cmdline.txt but make changes in raspi-config.
If you don't want to use the serial console you can remove it by either means.
You don't say which model Pi you are using. The Pi3 uses /dev/ttyAMA0 for Bluetooth and swaps the miniUART to the serial pins.
You can use /dev/ttyAMA0 on an older Pi or /dev/ttyS0 on Pi3. In the latest software there should be a /dev/serial0 which selects the appropriate device.
There appears to be some problems on the Pi3 with varying baudrate.
I modified the /boot/config.txt by adding the following line at the end:-
core_freq=250
