I would like to enable or disable portion of ARM L2 's cache memory of raspberry PI. I am working on performance evaluation of raspberryPI by locking the cache memory of it. Please suggest me some ideas on this.
Asked
Active
Viewed 894 times
All you need to do is add the following to your /boot/config.txt file. Here is the source page.
disable_l2cache=1
disable_l2cache disable ARM access to GPU's L2 cache. Needs corresponding L2 disabled kernel. Default 0
But I think for this to actually work, you will need to compile a custom kernel. So replace your kernel.img with your custom one, which has the L2 cache disabled. Also have a look at berryboot which allows you to install different versions of the same Linux on your SD card.
Vincent P
- 2,210
- 15
- 24
