I have connected laptop and Raspberry pi 3 to one Wifi router. But I can't connect to Raspberry via SSH from my laptop. On raspberry SSH is enabled and I can connect to it from Raspberry itself. Here are some settings I have:
sudo service ssh status >>>>>>
ssh.serice - OpenBSD Secure Shell server
Active: active (running)
raspberrypi systemd[1]: Started OpenBSD Secure Shell server
raspberrypi sshd[503]: Server listeting on 0.0.0.0 port 22
raspberrypi sshd[503]: Server listeting on :: port 22
/etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
allow-hotplug wlan1
iface wlan1 inet manual
ifconfig info
wlan0   inet addr:169.254.206.211 Bcast:169.254.255.255 Mask 255.255.0.0
I tried to connect on ubuntu like this:
ssh pi@169.254.206.211
And on windows via Putty
lomboboo
  • 103
lomboboo
You appear to be attempting to set static IP address in /etc/network/interfaces. This will not work. See the following tutorial
How do I set up networking/WiFi/Static IP
EDIT I may be misinterpreting what you have in /etc/network/interfaces. As posted this implies that you have added wlan0 inet addr:169.254.206.211 Bcast:169.254.255.255 Mask 255.255.0.0
In addition 169.254.206.211 will not work through a router. This is a link-local address and is not routable.
If you have not entered this it implies that DHCP has not assigned an IP address.
Have you checked the setting of your WLAN Box? There must be a checkbox down in the menu. It must be activated so that your computers can "talk" directly to each other in your WLAN net.
Hope I could help you.
Regards
Hirsch
