I am doing some research into using the Pi to host an iOS app. It seems like the Pi's performance as a normal web server is actually quite impressive (especially when compared to the control server used in the test).
Neo4j is an open source NoSQL graph database. I think this could be a great solution for small apps needing this kind of backend.
Has anyone installed and tested the Pi running Neo4j? Is the performance acceptable?
Adam Carter
  • 141
Does this help? https://gist.github.com/widged/8329039
edit added below instructions
Installation instructions for on a Pi : Install Java 7
~:$ sudo apt-get update
~:$ sudo apt-get install oracle-java7-jdk
~:$ sudo apt-get install openjdk-7-jre
~:$ sudo apt-get install lsof
Download Neo4J
~:$ cd ~
~:$ mkdir neo4j
~:$ cd neo4j
~:$ wget -O neo4j-community-2.0.0.tgz 'http://download.neo4j.org/artifact?edition=community&version=2.0.0&distribution=tarball'
~:$ tar xvf neo4j-community-2.0.0.tgz
~:$ cd neo4j-community-2.0.0/conf
OR for the newest branch
~:$ wget -O neo4j-community-2.1.5.tgz 'http://download.neo4j.org/artifact?edition=community&version=2.1.5&distribution=tarball'
~:$ tar xvf neo4j-community-2.1.5.tgz
~:$ cd neo4j-community-2.1.5/conf
Edit & Add Neo4J Propertie file
~:$ nano neo4j.properties
 neostore.nodestore.db.mapped_memory=1M
 neostore.relationshipstore.db.mapped_memory=1M
 neostore.propertystore.db.mapped_memory=1M
 neostore.propertystore.db.strings.mapped_memory=1M
 neostore.propertystore.db.arrays.mapped_memory=1M
Edit & Add Neo4J wrapper configuration
~:$ nano neo4j-wrapper.conf
 wrapper.java.additional=-XX:MaxPermSize=32M
 wrapper.java.initmemory=96
 wrapper.java.maxmemory=96
Make Neo4J known
~:$ export NEO4J_HOME=~/neo4j/neo4j-community-2.0.0
OR
~:$ export NEO4J_HOME=~/neo4j/neo4j-community-2.1.5
~:$ export PATH=$NEO4J_HOME/bin:$PATH
**Run Neo4J **
~:$ neo4j status
~:$ neo4j start
For neo4j 2.0.0 this should work, I myself did not success with neo4j 2.1.5 but did not have time to look into it.
Edzob
