My pi already setup and update with raspbian debian 8
But i can not install hhvm even add source deb to etc/apt/source.list.d/hhvm.list
Pi said can't locate hhvm package
How to install hhvm
The Raspberry Pi 3 appears to support an arm64 architecture.
If using a Raspberry Pi 3 or more recent, you might want to try to compile HHVM on arm64.
- 121
- 3
You cannot install HHVM on any version of the Raspberry Pi. According to the installation documents (specifically regarding compiling from source), you need a 64 bit operating system.
If you can get a 64 bit operating system running on the RPi 3, you may have a chance, but I highly doubt it.
- 11,904
- 7
- 47
- 58
You'll need a 64-bit ARM (AArch64) OS build for HHVM as well as 64-bit hardware.
Raspbian is 32-bit and Linux support is very much "experimental" where it is present. https://raspberrypi.stackexchange.com/a/73255/8074 says there a Pi64 build of Debian 9. Patches were uploaded by Suse for hardware support, and Arch Linux seems to have a build.
FreeBSD 12 is looking a bit better (and has the benefit of not being Linux) as it has an arm64/rpi3 image, more info on that is available in the FreeBSD Wiki.
- 166
- 5
