Following on from my woes at trying to use Samba to share media from my windows machine (SMB performance issues on Raspbmc) i thought i'd try (and share) my knowledge of getting my Windows XP Pro Machine running as an NFS server instead.
There has probably been many variations on doing this, but i hadn't seen one that matched my setup, a setup that i feel many people still have.
XP Pro server
Spec : Pentium IV 3.4Ghz 4GB ram, 500Gb Sata-II drive, edimax wireless PCI card.
IP : 192.168.1.40
Raspberry Pi
RaspBmc - Nightly build 12/1/2013
External Powered USB Hub with : Logitech K260 Wireless Key/mouse & TP Link WN823N Wireless USB & Bluetooth USB.
IP : 192.168.1.100
kolin
  • 950
  • 25
How I did it
INSTALLING NFS
http://technonstop.com/tutorial-setup-nfs-server-windows
Followed the instructions from several websites.
1) Firstly, Grab the "Services for unix for windows" from : http://www.microsoft.com/en-gb/download/details.aspx?id=274
2) Do a custom install, selecting only
  • NFS -> Server for NFS
  • Authentication tools for NFS -> User Name Mapping
  • Authentication tools for NFS -> User Name Server for NFS authentication
3) During install select the behaviour to Case Sensitive
4) Next, select Local User Mapping Server -> Password and group files
-- My addition The next stage asks you to upload passwd and group files, I simply created 2 files on the XP desktop. From this post : http://www.networkedmediatank.com/showthread.php?tid=1434&pid=460253#pid460253 I modified the passwd/group files
passwd
root:x:0:0:root:/root:/bin/sh
pi:x:1000:1000:pi:/home/pi:/bin/sh
group
root:x:0:
pi:x:1000:
to represent the Raspberry pi user.
5) Once the installation was complete, go start -> windows services for unix -> services for unix administration
6) select User Name Mapping on the left, and then the maps option on the right. I didn't select Simple maps, and decided to use advanced maps
Show User Maps
click list windows users and list unix users. from windows select Administrator from unix select pi then click add ignoring the warning about administrator special account
Show Group Maps
click list windows groups and list unix groups. from windows select Administrators from unix select pi then click add
Then apply in the top right.
Setting up shares
1) For each of my shares E:\music and E:\movies i right clicked on the folders in windows explorer, selected sharing and security and then the NFS Sharing tab.
2) Within the tab I created the share names music and movies with an encoding of ANSI, unchecking anonymous access
3) Within the permissions button, i unchecked Allow root access and selected Read/Wite as the type of access
4) Ok'd all this
5) Within /etc/fstab on the raspberry pi (via PuTTy) sudo nano /etc/fstab I added the following lines:
192.168.1.40:/music /home/pi/music  nfs defaults,user,auto,noatime,intr 0   0
192.168.1.40:/movies    /home/pi/movies nfs defaults,user,auto,noatime,intr 0   0
(obviously after creating the relevant directories within /home/pi)
Firewall setup
Unfortunately the initial firewall port opening specified in the bottom of this post : http://www.networkedmediatank.com/showthread.php?tid=1434&pid=460252#pid460252 didn't appear to work for me, however (shock) microsoft was on hand to offer that perhaps I should try and open some other ports too.
User Name Mapping and Server for NFS    Portmapper                  TCP, UDP        111
Server for NFS                          Network Status Manager      TCP, UDP        1039
Server for NFS                          Network Lock Manager        TCP, UDP        1047
Server for NFS                          NFS Mount                   TCP, UDP        1048
Server for NFS                          Network File System         TCP, UDP        2049
(from http://technet.microsoft.com/en-us/library/cc753302(v=ws.10).aspx )
DONE! I added the new mounts as sources in both music and movies, and they appear much much more responsive than samba
kolin
  • 950
  • 25
This is peachy for WinXP, but less good for other versions of Windows, which MS explicitly say their "services for Unix" won't work with.
FreeNFS doesn't work for me (reasons still TBD), and others are paid-for. The only free Windows NFS server I've found which works is on CodeProject.
http://www.codeproject.com/Articles/309936/Csharp-NET-Network-File-System-NFS-Server?msg=4719043#xx4719043xx
I've got some improvements to this (most importantly setting a "virtual root" so that you don't have to expose your whole C: drive) which hopefully will get rolled back into his codebase. It's not the prettiest code ever, and there are definitely ways its performance can be improved, but it does the job perfectly well for mounting a root filesystem.
Graham
