I would like to know if it is safe to edit the config.txt file on a Retropie image to change the arm_freq=800 to arm_freq=1200 since it will be running on a R-pi 3 model B?
Asked
Active
Viewed 1.3k times
- 60,325
- 17
- 117
- 234
Kenneth Spear
- 436
- 2
- 5
- 12
The Raspberry Pi 3 Model B starts at 1.2Ghz regardless of what /boot/config.txt says. Here are the results of my clock speed files on my Pi 3 with config.txt not edited from a fresh card:
sudo cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
1200000
When not under load:
sudo cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
600000
When playing music with mpg321:
1200000
You do not need to change /boot/config.txt if you want your Pi 3 running at 1.2Ghz, if you want to overclock it, that is a whole different question. Hope this helps.
Patrick Cook
- 6,365
- 8
- 38
- 63
