I am looking for a simple way to start a simple .exe program on every bootup using rc.local (unless there's an easier way).
Currently, the executable program I want to run is located in: /home/pi/boot and is running properly using the sudo mono command.
I am trying to make this run at boot in the rc.local and I currently just have:
sudo /home/pi/boot/EXENAME.exe
of course I have the #!/bin/sh -e at the top of the file but not sure exactly how I should get this working.
Ghanima
  • 15,958
  • 65
Sharks
  • 33
.exe files will only run under mono. Prefix your file location with 'mono' in your script and it should work.
goobering
  • 10,750
  • 40
  • 64
You should not be using rc.local assuming you are running a recent Raspbian which uses systemd. systemd will attempt to convert a well structured sysV script to a service, so it should still work.
An alternative for this case is to use cron.
You add commands to crontab by editing with crontab -e. E.g. I have @reboot sudo python /home/pi/shutdown_daemon.py in mine to run a program at boot.
There is a good tutorial at https://www.raspberrypi.org/documentation/linux/usage/cron.md
NOTE The first thing you should do (with ANY method) is run the program manually to ensure it actually works and the correct syntax.
