I just purchased an Eleduino 1024x600 IPS HDMI Capacitive touchscreen, assembled it, powered it with external USB (a Pi2's USB was unable to keep it on), and tried the following using a Redmere HDMI cable:
- Pi2, booting into a text console login
- Static patterns
- Pi3, console login
- Blinking vertical thick line
- Pi3, starting at console login as before, then hit enter on startx
- white with vertical lines; lines shift when mouse moved
- fine low-resolution display when switched back to a real monitor
- Pi2 with /boot/config.txt set to hdmi_safe = 1, framebuffer_width=1024, framebuffer_height=600,config_hdmi_boost=4 uncommented
- blackish pattern
Note that the NOOBS boot puts differing patterns of lines on the screen until it hits the console, instead of the normal color pattern followed by an option to go into recovery.
