25
It looks like the Raspberry Pi 3 may be powerful enough to output 4K video, but I haven't seen anything about it anywhere.
Does anyone know if the Raspberry Pi 3 can output video over HDMI at 4K resolution? If so, is it 30Hz or 60Hz?
Chris Pietschmann
  • 543
The best information I can find suggests that it's possible to output 4K resolutions, but at fairly miserable frame rates. The Pi 3 has the same GPU as the Pi 2, so the information should still be valid:
Source: https://www.raspberrypi.org/forums/viewtopic.php?f=38&t=79330
I have managed to get 3840 x 2160 (4k x 2k) at 15Hz on a Seiki E50UY04 working under two distributions on the Raspberry Pi... (Latest Wheezy/Openelec). The television shows it is receiving this resolution and hertz level, and it looks very crisp.
This is my config.txt for wheezy:
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
overscan_left=-150
overscan_right=-150
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=3840
#framebuffer_height=2160
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=87
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# for more options see http://elinux.org/RPi_config.txt
hdmi_ignore_edid=0xa5000080
hdmi_cvt 3840 2160 15
goobering
  • 10,750
  • 40
  • 64
I think you will be able to play but the frame rate should be very less else choppyness will be there or it might stuck at a frame as well.
-4
Try Chromecast 4k, you can stream from the RPi to Chromecast.
Jacobm001
  • 11,904
  • 47
  • 58
Rene
