9
i'm rather new to Linux and all that, in fact the Raspberry Pi 3 i just got is the first Linux-only machine i ever had, running the latest version of Raspbian .. so here's my problem:
I'm trying to use the integrated wifi adapter to establish a connection to my network / the interhet.
I do see my network showing up and i can try to connect to it, but it keeps either doing nothing (if i use the GUI thingie in the top right corner of the screen [sorry, i'm sure it has a propper name but i couldnt see any]) or it sais that the authentication failed when i try it with wpa_gui
Now here are my specs, i hope i get everything in there that is needed:
ifconfig -a says:
eth0      Link encap:Ethernet  HWaddr b8:27:eb:6e:78:19
      inet addr:192.168.0.163  Bcast:192.168.0.255  Mask:255.255.255.0
      inet6 addr: 2a02:810a:11c0:2c8c:dfe1:d49f:7f8c:a4a1/64 Scope:Global
      inet6 addr: fe80::eac9:60d9:4260:247c/64 Scope:Link
      UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
      RX packets:8277 errors:0 dropped:0 overruns:0 frame:0
      TX packets:7779 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:6894047 (6.5 MiB)  TX bytes:1298763 (1.2 MiB)
lo        Link encap:Local Loopback
      inet addr:127.0.0.1  Mask:255.0.0.0
      inet6 addr: ::1/128 Scope:Host
      UP LOOPBACK RUNNING  MTU:65536  Metric:1
      RX packets:136 errors:0 dropped:0 overruns:0 frame:0
      TX packets:136 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:0
      RX bytes:11472 (11.2 KiB)  TX bytes:11472 (11.2 KiB)
wlan0     Link encap:Ethernet  HWaddr b8:27:eb:3b:2d:4c
      BROADCAST MULTICAST  MTU:1500  Metric:1
      RX packets:517 errors:0 dropped:517 overruns:0 frame:0
      TX packets:30 errors:0 dropped:0 overruns:0 carrier:0
      RX bytes:165242 (161.3 KiB)  TX bytes:5325 (5.2 KiB)'
my etc/network/interfaces file i modified quite a few times already, trying out several things, currently its looking like this:
auto wlan0
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
iface default inet dhcp
and the etc/wpa_supplicant/wpa_supplicant.conf has this here:
update_config=1
network={
    ssid="MySSID"
    psk="MyPsk"
    proto=RSN
    key_mgmt=WPA-PSK
    pairwise=TKIP
    auth_alg=OPEN
The network i am trying to connect to is WPA2 PSK encrypted with TKIP, my only guess here is that i have to make some settings either in Raspbian's wpa_supplicant.conf or in my router to let the two of them communicate with each other?
Or am i missing something totally obvious here?
I would also be grateful for hints on what tools i can use under Linux to figure this problem out and see where what goes wrong :)
Thanks a lot in advance and sorry if i messed up any english ;)
Ken Williams
  • 103
Virus Ex
  • 141
I solved the problem.
First I updated my settings as suggested in the link that Miliways provided in a comment in my original answer.
That alone didn't solve it, what I actually had to do is change the configurations in my router:
The WiFi was set to WPA2/WPA -> I changed that to WPA2 only and now I can finally connect to the network without problems.
If there are configs that I would need to adjust in order to make WiFi work with WPA2/WPA settings in the router, I would be glad if anyone could provide these, I couldn't find anything considering that on the internet.
Virus Ex
  • 141
I've had problems before with using a pre-shared key, especially when I forgot to escape characters that needed to be escaped. Characters that may need to be escaped would be (among others):
You escape a character by adding a '\' before it, so for example if your key was:
P@ssword"!
You would escape it like:
P\@ssword\"\!
Likewise, if you needed the character \ in your password, you would escape it by prefixing like \\.
In this case, you haven't shared the key (good!), but have you made sure that it's properly escaped? If possible, could you change it to a key that's only alpha-numeric and try for troubleshooting purposes?
I don't see anything in the configuration that you've provided that points to any other configuration issue.
Ficertyn
  • 171
