I have a Raspberry Pi 2 which was running successfully with Wheezy. I decided to upgrade to Jessie. When I plug in the external USB drive (LaCie Rugged THB USB 3.0), it crashes. I did an ssh and tailed the log while I plugged in the USB external drive and then it crashed:
Mar  3 19:53:38 raspberrypi kernel: [   90.094492] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
Mar  3 19:53:38 raspberrypi kernel: [   90.236915] usb 1-1.2: New USB device found, idVendor=059f, idProduct=1075
Mar  3 19:53:38 raspberrypi kernel: [   90.236944] usb 1-1.2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
Mar  3 19:53:38 raspberrypi kernel: [   90.236961] usb 1-1.2: Product: Rugged THB USB 3.0
Mar  3 19:53:38 raspberrypi kernel: [   90.236976] usb 1-1.2: Manufacturer: LaCie
Mar  3 19:53:38 raspberrypi kernel: [   90.236991] usb 1-1.2: SerialNumber: XXXXXXXXXXXF
Mar  3 19:53:38 raspberrypi kernel: [   90.238106] usb-storage 1-1.2:1.0: USB Mass Storage device detected
Mar  3 19:53:38 raspberrypi kernel: [   90.242697] scsi host0: usb-storage 1-1.2:1.0
Mar  3 19:53:39 raspberrypi kernel: [   91.235481] scsi 0:0:0:0: Direct-Access     LaCie    Rugged THB USB3  1153 PQ: 0 ANSI: 6
Mar  3 19:53:39 raspberrypi kernel: [   91.238863] sd 0:0:0:0: [sda] Spinning up disk...
Mar  3 19:53:39 raspberrypi kernel: [   91.254023] sd 0:0:0:0: Attached scsi generic sg0 type 0
Mar  3 19:53:40 raspberrypi kernel: [   92.244466] .
Mar  3 19:53:40 raspberrypi kernel: [   92.414881] usb 1-1-port2: over-current change
Mar  3 19:53:41 raspberrypi kernel: [   92.671043] usb 1-1.2: USB disconnect, device number 4
Mar  3 19:53:41 raspberrypi kernel: [   93.254476] .ready
Mar  3 19:53:41 raspberrypi kernel: [   93.254905] sd 0:0:0:0: [sda] Read Capacity(10) failed: Result: hostbyte=0x01 driverbyte=0x00
Mar  3 19:53:41 raspberrypi kernel: [   93.254931] sd 0:0:0:0: [sda] Sense not available.
Mar  3 19:53:41 raspberrypi kernel: [   93.255026] sd 0:0:0:0: [sda] Write Protect is off
Mar  3 19:53:41 raspberrypi kernel: [   93.256447] sd 0:0:0:0: [sda] Read Capacity(10) failed: Result: hostbyte=0x01 driverbyte=0x00
Mar  3 19:53:41 raspberrypi kernel: [   93.256469] sd 0:0:0:0: [sda] Sense not available.
Mar  3 19:53:41 raspberrypi kernel: [   93.256632] sd 0:0:0:0: [sda] Attached SCSI disk
Mar  3 19:53:42 raspberrypi kernel: [   93.934461] usb 1-1.2: new high-speed USB device number 5 using dwc_otg
Mar  3 19:53:42 raspberrypi kernel: [   94.076561] usb 1-1.2: New USB device found, idVendor=059f, idProduct=1075
Mar  3 19:53:42 raspberrypi kernel: [   94.076581] usb 1-1.2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
Mar  3 19:53:42 raspberrypi kernel: [   94.076592] usb 1-1.2: Product: Rugged THB USB 3.0
Mar  3 19:53:42 raspberrypi kernel: [   94.076603] usb 1-1.2: Manufacturer: LaCie
Mar  3 19:53:42 raspberrypi kernel: [   94.076613] usb 1-1.2: SerialNumber: XXXXXXXXXXXF
Mar  3 19:53:42 raspberrypi kernel: [   94.077411] usb-storage 1-1.2:1.0: USB Mass Storage device detected
Mar  3 19:53:42 raspberrypi kernel: [   94.077773] scsi host1: usb-storage 1-1.2:1.0
Mar  3 19:53:42 raspberrypi kernel: [   94.463130] usb 1-1-port2: over-current change
Mar  3 19:53:43 raspberrypi kernel: [   94.719224] usb 1-1.2: USB disconnect, device number 5
Mar  3 19:53:44 raspberrypi kernel: [   95.974460] usb 1-1.2: new high-speed USB device number 6 using dwc_otg
Mar  3 19:53:44 raspberrypi kernel: [   96.116551] usb 1-1.2: New USB device found, idVendor=059f, idProduct=1075
Mar  3 19:53:44 raspberrypi kernel: [   96.116575] usb 1-1.2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
Mar  3 19:53:44 raspberrypi kernel: [   96.116587] usb 1-1.2: Product: Rugged THB USB 3.0
Mar  3 19:53:44 raspberrypi kernel: [   96.116597] usb 1-1.2: Manufacturer: LaCie
Mar  3 19:53:44 raspberrypi kernel: [   96.116607] usb 1-1.2: SerialNumber: XXXXXXXXXXXF
Mar  3 19:53:44 raspberrypi kernel: [   96.117732] usb-storage 1-1.2:1.0: USB Mass Storage device detected
Mar  3 19:53:44 raspberrypi kernel: [   96.118206] scsi host2: usb-storage 1-1.2:1.0
Mar  3 19:53:44 raspberrypi kernel: [   96.511399] usb 1-1-port2: over-current change
Mar  3 19:53:45 raspberrypi kernel: [   96.767492] usb 1-1.2: USB disconnect, device number 6
Mar  3 19:53:46 raspberrypi kernel: [   98.024483] usb 1-1.2: new high-speed USB device number 7 using dwc_otg
Mar  3 19:53:46 raspberrypi kernel: [   98.565110] usb 1-1-port2: over-current change
Mar  3 19:53:48 raspberrypi kernel: [  100.074494] usb 1-1.2: new high-speed USB device number 9 using dwc_otg
Mar  3 19:53:48 raspberrypi kernel: [  100.216825] usb 1-1.2: New USB device found, idVendor=059f, idProduct=1075
Mar  3 19:53:48 raspberrypi kernel: [  100.216853] usb 1-1.2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
Mar  3 19:53:48 raspberrypi kernel: [  100.216870] usb 1-1.2: Product: Rugged THB USB 3.0
Mar  3 19:53:48 raspberrypi kernel: [  100.216885] usb 1-1.2: Manufacturer: LaCie
Mar  3 19:53:48 raspberrypi kernel: [  100.216900] usb 1-1.2: SerialNumber: XXXXXXXXXXXF
Mar  3 19:53:48 raspberrypi kernel: [  100.217989] usb-storage 1-1.2:1.0: USB Mass Storage device detected
Mar  3 19:53:48 raspberrypi kernel: [  100.218464] scsi host3: usb-storage 1-1.2:1.0
Mar  3 19:53:49 raspberrypi kernel: [  101.120067] usb 1-1-port2: over-current change
Mar  3 19:53:49 raspberrypi kernel: [  101.355329] usb 1-1.2: USB disconnect, device number 9
Mar  3 19:53:50 raspberrypi kernel: [  102.634485] usb 1-1.2: new high-speed USB device number 10 using dwc_otg
Mar  3 19:53:51 raspberrypi kernel: [  102.776880] usb 1-1.2: New USB device found, idVendor=059f, idProduct=1075
Mar  3 19:53:51 raspberrypi kernel: [  102.776907] usb 1-1.2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
Mar  3 19:53:51 raspberrypi kernel: [  102.776924] usb 1-1.2: Product: Rugged THB USB 3.0
Mar  3 19:53:51 raspberrypi kernel: [  102.776939] usb 1-1.2: Manufacturer: LaCie
Mar  3 19:53:51 raspberrypi kernel: [  102.776954] usb 1-1.2: SerialNumber: XXXXXXXXXXXF
Mar  3 19:53:51 raspberrypi kernel: [  102.778037] usb-storage 1-1.2:1.0: USB Mass Storage device detected
Mar  3 19:53:51 raspberrypi kernel: [  102.778517] scsi host4: usb-storage 1-1.2:1.0
Mar  3 19:53:51 raspberrypi kernel: [  103.168316] usb 1-1-port2: over-current change
Mar  3 19:53:51 raspberrypi kernel: [  103.424463] usb 1-1.2: USB disconnect, device number 10
Mar  3 19:53:53 raspberrypi kernel: [  104.684495] usb 1-1.2: new high-speed USB device number 11 using dwc_otg
Mar  3 19:53:53 raspberrypi kernel: [  105.245152] usb 1-1-port2: over-current change
Mar  3 19:53:55 raspberrypi kernel: [  106.734484] usb 1-1.2: new high-speed USB device number 13 using dwc_otg
Mar  3 19:53:55 raspberrypi rsyslogd-2007: action 'action 17' suspended, next retry is Thu Mar  3 19:54:25 2016 [try http://www.rsyslog.com/e/2007 ]
Mar  3 19:53:55 raspberrypi kernel: [  106.876886] usb 1-1.2: New USB device found, idVendor=059f, idProduct=1075
Mar  3 19:53:55 raspberrypi kernel: [  106.876916] usb 1-1.2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
packet_write_wait: Connection to 192.168.1.5: Broken pipe
I have zero problems with this drive before on Wheezy. If I plug in this USB drive and plug the Raspberry Pi 2 in, it won't boot. I have tested this same drive on another Linux system and it worked perfectly.
Anything from the above log indicate what to do about this problem? Are there additional things for USB drives to install?
Edward_178118
  • 209
The lines:
Mar  3 19:53:42 raspberrypi kernel: [   94.463130] usb 1-1-port2: over-current change`
imply that somethings is wrong the the voltage that's being supplied to the drive. So there's a couple things that may be at work here.
Upgrade Woes:
The change from Wheezy to Jessie was drastic. So drastic that the foundation recommends not upgrading system in place, but rather doing a complete reinstall from a fresh image. There could be a number of systems that didn't handle the upgrade well, and are causing issues.
This might be fixable by going through different settings and doing a guess and check, but a reinstall would probably be easier/faster. It might be worth checking the max output settings in config.txt, but again, I'd suggest a clean install.
Possible Hardware Issues:
Either the drive or the port may have shorted. If it happens on the RPi, but works on the desktop, than the RPi may be damaged. If it doesn't work on the computer either, your drive is damaged.
The best way to check the RPi's ports would be to use a multimeter to check the power output of the USB ports. If you don't have one, try a different drive. If it reacts similarly, you're back to the RPi have some kind of issue.
Jacobm001
  • 11,904
  • 47
  • 58
