I'm trying to stream video from the camera module using ffserver. My server configuration is
HTTPPort 8090
HTTPBindAddress 0.0.0.0
MaxHTTPConnections 8
MaxClients 4
MaxBandwidth 1000
CustomLog -
#NoDaemon
<Feed feed1.ffm>
File /tmp/feed1.ffm
FileMaxSize 5M
ACL allow 127.0.0.1
</Feed>
<Stream live.flv>
Feed feed1.ffm
NoAudio
</Stream>
# Special streams
<Stream stat.html>
Format status
# Only allow local people to get the status
ACL allow localhost
ACL allow 192.168.0.0 192.168.255.255
</Stream>
# Redirect index.html to the appropriate site
<Redirect index.html>
URL http://www.ffmpeg.org/
</Redirect>
I run
ffserver -f server.conf &
and then
raspivid -t 0 -w 640 -h 480 -b 1024000 -fps 5 -ih -n -o - | \
ffmpeg -i - -c:v copy -r 5 -an -f flv -override_ffserver \
http://localhost:8090/feed1.ffm
However ffmpeg complains
[flv @ 0x215e520] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
Thu Mar 3 02:58:36 2016 127.0.0.1 - - [POST] "/feed1.ffm HTTP/1.1" 200 276
av_interleaved_write_frame(): Connection reset by peer
[flv @ 0x215e520] Failed to update header with correct duration.
[flv @ 0x215e520] Failed to update header with correct filesize.
Error writing trailer of http://localhost:8090/feed1.ffm: Connection reset by peer
and then quit.
How do I fix this?
BTW, I tested raspivid and ffmpeg with something like
raspivid -t 0 -w 640 -h 480 -o - | ffmpeg -i - -c:v copy test.mkv
and it worked normally.
