I'd like to use VirtualBox at first and instead of Raspbian, Ubuntu Mate.
Should I expect some differences while setting up a 3G connection?
For the command line, not the GUI:
Major differences? No.
Differences? Not really.
Here is a Raspbian wifi tutorial and an Ubuntu Mate wifi tutorial.
Both OSs use the files /etc/network/interfaces and /etc/wpa_supplicant/wpa_supplicant.conf. Which both use the same formatting/syntax.
I wouldn't expect anything major to change. I'm sure looking at the Raspbian tutorial and figuring out what exactly what is different as you go wouldn't be too hard. But I doubt there are any differences.
VirtualBox is operating system level (aka. paravirtualization) software designed exclusively for x86(-64) systems and as such cannot run on any model of Raspberry Pi.
Since Pi operating systems all target ARM, VirtualBox cannot be used to run Raspbian directly. I think you are aware of this.
WRT setting up a 3G connection the fundamentals are the same since this is kernel driven. How you configure and interface with this depends upon the software you use, but it should be possible to do in a more-or-less identical way.
