I have had a hard time with this Pi, finding the drivers was not a easy task, and now am experiencing a new issue.
My WiFi dongle is flashing green (which is a good sign). In the GUI WiFi setup it's saying I am connected, but problem is I don't have a IP address nor am I able to ping or connect to the internet.
Interfaces File
update_config=1
network={
        ssid="Claro"
        psk="password12"
        proto=RSN
        key_mgmt=WPA-PSK
        group=CCMP TKIP
GNU nano 2.2.6 File: /etc/network/interfaces
auto lo
iface lo inet loopback
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
I am running Raspbian Wheezy.
angussidney
  • 703
TravJav92
Try putting this in your /etc/network/interfaces file:
auto lo
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-ssid "Claro"
wpa-psk "password12"
1''
  • 246
Changed to Jessie worked out of the box. Had issue with voltage because my usb port was hogging energy, as well as using a host-dependendent USB hub.. solution was to use independent USB hub or just use SSH, works amazing.
TravJav92
