I am using a speech recognition library on a Raspberry Pi in Python that I found here and I installed it through pip. I also had to install Pyaudio of their site here. Pip would not work for Pyaudio so I installed it through the package manager. I need Pyaudio to work with my USB microphone
Now on the Speech Recognition site there was a terminal command to test the library. python -m speech_recognition
After doing this I got the folowing error (Sorry for the super long error):
A moment of silence, please...
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.front.0:CARD=0'
ALSA lib conf.c:4259:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:4738:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM front
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround51.0:CARD=0'
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround21
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround40.0:CARD=0'
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround40
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround41
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround50
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround51
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround71.0:CARD=0'
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround71
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM iec958
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM spdif
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
Set minimum energy threshold to 397.181000779
Say something!
  File "/usr/lib/python2.7/runpy.py", line 162, in _run_module_as_main
    "__main__", fname, loader, pkg_name)
  File "/usr/lib/python2.7/runpy.py", line 72, in _run_code
    exec code in run_globals
  File "/usr/local/lib/python2.7/dist-packages/speech_recognition/__main__.py", line 12, in <module>
    with m as source: audio = r.listen(source)
  File "/usr/local/lib/python2.7/dist-packages/speech_recognition/__init__.py", line 349, in listen
    buffer = source.stream.read(source.CHUNK, exception_on_overflow = False)
TypeError: read() got an unexpected keyword argument 'exception_on_overflow'
Jacobm001
  • 11,904
  • 47
  • 58
