I was thinking of a program that would grant access to the raspberry pi usb port if the user was authorized and disable it if not. Most of the links I found are regarding the usb port supply, while it is conducive i think it is much safer if the transmit and receive pin at the usb port can be toggled. Thank you in advance!
Asked
Active
Viewed 98 times
Just like this question/answer suggests, there is no way to cut the power or the TX/RX on the USB ports with just software. You will need to add a transistor and do some fancy wiring, which is all described in the answer to that question.
Patrick Cook
- 6,365
- 8
- 38
- 63
