First off, I am on Raspberry Pi B+, and I have just changed its IP address to static. Since I just changed the IP address to static, I go to my browser and type my Raspberry Pi's IP address, which I know for a fact, which I'll just say is 180.360.1.1.
So, I have my Raspberry Pi all powered up, and then I go to my browser and type in 180.360.1.1. However, it just sort of doesn't 'register', or doesn't have any results, so it just shows my internet provider, and list of website suggestions as usual when there is not a result.
Any help? It's been working until now. I used this tutorial: How To Assign A Static IP to The Raspberry Pi.
User98764431
  • 569
  • 33
Darkfyi
You do not have to assign a private address to your apache server. You do however, have to assign an address that is reachable from the web browsing client. If you give the apache server an address on the same subnet as your web browsing client, apache would be reachable.
You can test if the apache server is reachable by going to the command line on your client and typing: ping 180.180.1.1 . (180.360.1.1… not a valid IPv4 address.)
It seems that your web browser is not forming the http request properly. Typically, you see a web page from your internet provider and a list of website suggestions only when a DNS query fails. You should not see that when entering an IP address.
Try entering the full path in the address bar:
http://180.180.1.1/
medbot
  • 96
You have to use a private IP address starting from 192.168.0.1 to 192.168.0.254. Choose one and attach it to your raspberry. Then it should work.
Jacobm001
  • 11,904
  • 47
  • 58
user41668
