I am trying to use my Raspberry Pi Zero together with my Raspberry Pi 2 and I want to share network access from my Raspberry Pi 2 to my Raspberry Pi Zero. I can easily create a local network connection between my Raspberry Pis, but I have a problem sharing network access.
First of I followed this guide, Adafruit - Turning your Raspberry PI Zero into a USB Gadget - Ethernet Gadget, to turn my Raspberry Pi Zero into a Ethernet gadget. Then I added this to /etc/network/interfaces:
allow-hotplug usb0
iface usb0 inet static
address 10.0.1.2
netmask 255.255.255.0
gateway 10.0.0.1
I configured usb0 on my Raspberry Pi 2 like this:
allow-hotplug usb0
address 10.0.1.1
gateway 10.0.0.1
I could ssh into my Raspberry Pi Zero with ssh pi@10.0.1.2 but my next goal was to share network access, so I could run stuff like ping google.com on my Raspberry Pi Zero. I found this guide, Configuring Raspberry Pi as a Wireless-to-Wired Ethernet Island, which explains how to forward network access from wlan0 to eth0 and I tried doing the same with usb0.
I added pre-up iptables-restore < /etc/network/iptables.conf to /etc/network/interfaces. This is the content of my iptables.conf file:
# Generated by iptables-save v1.4.21 on Tue Feb 16 16:41:38 2016
*mangle
:PREROUTING ACCEPT [472:58950]
:INPUT ACCEPT [324:32281]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [30694:35635555]
:POSTROUTING ACCEPT [30694:35635555]
COMMIT
# Completed on Tue Feb 16 16:41:38 2016
*filter
:INPUT ACCEPT [57:4180]
:OUTPUT ACCEPT [2194:2536976]
-A FORWARD -i usb0 -j ACCEPT
-A FORWARD -i wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT
COMMIT
*nat
:PREROUTING ACCEPT [6:821]
:INPUT ACCEPT [1:242]
:OUTPUT ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
-A POSTROUTING -o wlan0 -j SNAT --to-source 10.0.0.115
COMMIT
I enabled ip forwarding in the kernel by uncommenting this line in /etc/sysctl.conf
# Uncomment the next line to enable packet forwarding for IPv4
net.ipv4.ip_forward=1
Finally I executed sysctl --system.
Unfortunately the network is still unreachable on my Raspberry Pi Zero after rebooting both my Raspberry Pi 2 and Raspberry Pi Zero. This is the output of route on my Raspberry Pi 2:
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 10.0.0.1 0.0.0.0 UG 0 0 0 wlan0
10.0.0.0 * 255.255.255.0 U 0 0 0 wlan0
10.0.1.0 * 255.255.255.0 U 0 0 0 usb0
