I'm working on setting up a kiosk and I'm trying to decide with OS to install on the Pi. I know a full Raspbian install will work, but this site will be hosted locally and updated only a couple times per year. So, I don't want to use a full distro if I don't have to just to minimize maintenance.
I'm wondering if I can open the Chrome browser in kiosk mode without booting to desktop, which would allow me to use something like Jessie Lite or DietPi. Or, do I have to enter the GUI first?
Any suggestions would be helpful.
Brian
  • 211
I finally managed to find a good guide to get Jessie Lite up and running without booting to desktop as default.
You still need to run Xserver to managed the windows, and you can use LightDM to manage the startup process. There are some other driver installs which optimize video performance on the ARM processor.
The big thing to pay attention to is that the Chromium build offered for Jessie is v45, which will only work on Raspberry Pi 2 or later. You can use a different browser, like Firefox or Epiphany, on an older machine.
Brian
  • 211
Try the following URL : http://blogs.wcode.org/2013/09/howto-boot-your-raspberry-pi-into-a-fullscreen-browser-kiosk/
I use it for autorun a web browser when raspbian start
Sidhi Ciang
  • 147
There are a lot of different ways you could do this. I know there are some tutorials on setting up Raspbian as a Kiosk, but for your purposes something like Screenly might be the way to go. If you use BerryBoot they have an Premade install for Screenly that is EXTREMELY easy to setup. The only major issue that I saw with Screenly was that it lost any Authentication from stored cookies upon reboot. So if it is an always on situation then Screenly would definitely work. The issue I ran into with some of the Kiosk Tutorials was that eventually the browsers would prompt for updates or would crash etc... requiring user interaction (I was creating a digital signage solution so this was unacceptable). Ultimately I ended up using Concerto for my backend (which would probably be way overboard for your needs) and Screenly as the client on the Pi's... Links to BerryBoot and Screenlys websites are below.
BerryBoot
Screenly
