17
I'm accessing my Pi via SSH.
My network is too slow to actually forward the Pi's desktop back to my laptop, so I have a monitor connected to my Pi. When I startx through Putty, I see the desktop on my Pi. All is good.
However, I cannot do anything with this desktop, as all I have is the mouse and keyboard of my laptop.
How can I forward the mouse and keyboard input from my laptop to the desktop on my Pi?
ACarter
  • 2,350
  • 25
  • 40
5 Answers5
14
You can use a great tool called x2x. This essentially treats the monitor connected to the remote device (the Raspberry Pi) as a second X screen to you existing session as if you had two monitors connected.
Install x2x on both devices:
sudo pacman -S x2x         # Arch Linux
sudo apt-get install x2x   # Debian/Raspbian
Configure SSH:
On the Raspberry Pi edit /etc/ssh/sshd_config and add/uncomment the following line:
X11Forwarding yes
Then restart the ssh server.
SSH to the Pi from your other device and run x2x:
ssh -X 192.168.0.70 'x2x -east -to :0'
Replace the IP with the address of your Raspberry Pi.
Now you should be able to move your mouse between the two X sessions by moving your mouse off the screen to the right (east).
Jivings
  • 22,656
  • 94
  • 140
10
synergy can do this quite well
Synergy lets you easily share your mouse and keyboard between multiple computers on your desk, and it's Free and Open Source. Just move your mouse off the edge of one computer's screen on to another. You can even share all of your clipboards. All you need is a network connection. Synergy is cross-platform (works on Windows, Mac OS X and Linux).
John La Rooy
  • 12,005
  • 48
  • 77
A quick google eventually led me here and after a quick test this worked for me.
In short you need to setup xrdp
sudo apt-get install xrdp
Once install it will set the rdp service to start on boot, so restart your RPi. When your RPi has finished booting you will be able to connect to your RPi through Windows built-in (or any other third party) remote desktop application.
Lukas Knuth
  • 949
Old thread... I know.
I've written a utility I call fauxcon, which forwards your keyboard (and soon, mouse) to the console of another computer you're ssh'd into.
This allows you to view your RPi's display (for instance) on a TV or monitor, and type as if you were logged into the physical device with a keyboard.
Considering everything in my house is wireless, it's rather neat to sit on the couch with laptop and type away, seeing it happen on the big screen on the RPi.
Feedback welcome,
fauxcon - Github - https://github.com/lornix/fauxcon
lornix
  • 1,066
I was in a similar situation and didn't want to use synergy because I was already running synergy on the computers I wanted to send the keyboard to and don't have X running on the host. I found uinput-mapper to be the perfect solution for my case.
Github: https://github.com/MerlijnWajer/uinput-mapper
How-to: http://blog.pi3g.com/2014/03/uinput-mapper-redirecting-keyboard-and-mouse-to-any-linux-system-using-a-raspberry-pi/
I used netcat instead of SSH since I'm not too worried about security on my LAN and it seems to intercept the keyboard before you can type your password. Must be run as root or more ideally just have privilege to mess with input devices.
On the computer in need of a keyboard:
# nc -l -p 7005|./input-create
Then on the computer with the keyboard:
# ./input-read -G /dev/input/eventX -D|nc 192.168.1.122 7005
(where eventX is your keyboard and 192.X.X.X is the computer you're sending the keyboard to)
It's had no speed issues and all the keys work correctly. I believe it works with mice too but I didn't have a need to use that.
Penguins55
