I'm running Jessie version on Raspberry Pi2. I'm trying to install Pulseaudio 8 from the source, but having problems running it in system mode with Bluez5 with A2DP support.
On startup in system-wide mode, it fails with "module-bluez5-discover.c: Failed to load module for device /org/bluez/hci0/dev_AC_CF_85_23_8C_78" error when I connect my phone to bluetooth.
If I simply restart pulseaudio under user account using:
pulseaudio -vvvv
and connecting the phone, everything works fine and I can play music via A2DP from the phone.
Pulseaudio is setup to run as systemd service in /etc/systemd/system/pulseaudio.service:
/usr/local/bin/pulseaudio --system --disallow-exit --disable-shm --exit-idle-time=-1 --disallow-module-loading
Here is the verbose log output when it fails to load module:
D: [pulseaudio] bluez5-util.c: dbus: path=/MediaEndpoint/A2DPSink, interface=org.bluez.MediaEndpoint1, member=SetConfiguration
D: [pulseaudio] bluez5-util.c: Transport /org/bluez/hci0/dev_AC_CF_85_23_8C_78/fd3 state changed from disconnected to idle
D: [pulseaudio] module-bluez5-discover.c: Loading module-bluez5-device path=/org/bluez/hci0/dev_AC_CF_85_23_8C_78
W: [pulseaudio] module-bluez5-discover.c: Failed to load module for device /org/bluez/hci0/dev_AC_CF_85_23_8C_78
D: [pulseaudio] bluez5-util.c: Transport /org/bluez/hci0/dev_AC_CF_85_23_8C_78/fd3 available for profile a2dp_source
D: [pulseaudio] bluez5-util.c: Unknown interface org.freedesktop.DBus.Introspectable found, skipping
D: [pulseaudio] bluez5-util.c: Unknown interface org.bluez.MediaPlayer1 found, skipping
D: [pulseaudio] bluez5-util.c: Unknown interface org.freedesktop.DBus.Properties found, skipping
Here is the same section when it manages load the module when I run pulseaudio under normal user account ("pi").
D: [pulseaudio] bluez5-util.c: Transport /org/bluez/hci0/dev_AC_CF_85_23_8C_78/fd6 state changed from disconnected to idle
I: [pulseaudio] module-card-restore.c: Restoring port latency offsets for card bluez_card.AC_CF_85_23_8C_78.
I: [pulseaudio] card.c: Created 1 "bluez_card.AC_CF_85_23_8C_78"
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card1/profile0
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card1/profile1
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card1/profile2
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Card added for object /org/pulseaudio/core1/card1
D: [pulseaudio] module-bluez5-device.c: Acquiring transport /org/bluez/hci0/dev_AC_CF_85_23_8C_78/fd6
I: [pulseaudio] bluez5-util.c: Failed optional acquire of unavailable transport /org/bluez/hci0/dev_AC_CF_85_23_8C_78/fd6
I: [pulseaudio] module-bluez5-device.c: SBC parameters: allocation=0, subbands=1, blocks=3, bitpool=2
I: [pulseaudio] source.c: Created source 1 "bluez_source.AC_CF_85_23_8C_78" with sample spec s16le 2ch 44100Hz and channel map front-left,front-right
I: [pulseaudio] source.c: bluetooth.protocol = "a2dp_source"
I: [pulseaudio] source.c: device.description = "Nexus 6P"
The only configuration change that I did to Pulseaudio was in /etc/pulse/system.pa, I added this:
### Bluetooth Support
.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover
.endif
I think I configured permissions correctly too:
pulse is added to audio
pulse is added lp
pi user is added to pulse-access
DBUS permissions are set as follows:
<busconfig>
<policy user="root">
<allow own="org.pulseaudio.Server"/>
<allow send_destination="org.bluez"/>
<allow send_interface="org.bluez.Manager"/>
</policy>
<policy user="pulse">
</policy>
<policy context="default">
<deny own="org.pulseaudio.Server"/>
<deny send_destination="org.bluez"/>
<deny send_interface="org.bluez.Manager"/>
</policy>
</busconfig>
My phone is paired and connected to bluetooth stack fine.
Can anyone help to understand why Pulseaudio doesn't want to work with Bluez in system mode ?
