Is there any way how to connect Dell Latirude D630 display B141PW03 V.0 to RPi?
I have working digitizer, working notebook which is useless for me.
Chetan Bhargava
  • 1,252
  • 29
antoninkriz
  • 143
Recently I made an tutorial about this ;) Hopefully it works for you, if you have any questions let me know!
https://www.youtube.com/watch?v=AKqygvB7Hds
Since both HDMI ports in both the Pi and in your lap top are output ports, you can't connect Pi directly to your lap top.
For the first time setup, try using the HDMI port in your TV screen. After that try googling How to connect to Raspberry Pi remotely.
You will be using some apps like PuTTY with Real VNC or Xming as an alternative of the latter.
Tes3awy
  • 323
you need LVDS controller boards for exact model of your Laptop Screen incase of yours you can buy from here so after having the board you need to have some case for sitting you can use acrylic glass wood or plastic!
Make Sure you have the correct LVDS driver
Hint: You can Buy the VGA version of LVDS and converting it in to HDMI using Cheap converter or buy the HDMI version Driver!
Isru
