I've had a few issues with HDMI. The first was no audio which I fixed. I suspect this other issue can be fixed in a similar fashion, but I am a super NOOB to all of this.
Basically, the image on my TV is right justified, with one thick black bar of nothingness on the left side of the screen. While not a huge problem, it has become a tad annoying. Any idea how to fix this? Thanks!
onipar
overscan would most likely fix this issue. See this post. And the official docs. Basically, overscan fine tunes the image size. You can change the overscan more precisely by editing config.txt but you shouldn't need to. But if you need to, check the official docs for config.txt. You would want to add/edit the parameter overscan_left= and set it equal to something smaller, just mess with the number and see what works best.
Patrick Cook
  • 6,365
  • 38
  • 63
