I am experiencing big problem with the Raspberry Pi 2 Wifi connection using a wifi dongle. The Wifi connection is working for a random time (sometimes a few minutes, sometimes a few hours) and then not working for another random time without changing anything.
This happens over and over again and I do not know how to solve this. Although I've tried several approaches I found in different Threads, i.e. this link https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=44044, nothing worked for me. I do not experience any problems with the router or the wifi with any other devices.
Please see below at the syslog that it says 'carrier lost' at the moment where the connection gets disrupted while I am pinging the router.
I already bought two usb dongles (Edimax EW-7811Un and LogiLink WL0084B) and another propper power supply that ensures a constant voltage of 5 Volts as I read that this is sometimes a problem. I also tried using a powered usb hub to connect the wifi stick but experienced the same behaviour.
My next step would be to ask the dealer for another Pi.
Can anybody help me with this problem? Help would be HIGHLY appreciated!!
Please find my setup and other information below:
After installing Raspbian Jessie (NOOBS) and updating and upgrading via apt-get:
sudo nano /etc/modprobe.d/8192cu.conf and I enter
options 8192cu rtw_power_mgnt=0 rtw_enusbss=0
sudo nano /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
iface default inet dhcp
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
network={
ssid=“my_SSID“
psk=“my_password“
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
auth_alg=OPEN
This is all I do after using a fresh raspbian. WPA Mode of the Router is WPA/WPA2.
When the internet is not working and I cannot ping the router anymore:
64 bytes from 192.168.1.1: icmp_seq=1035 ttl=64 time=0.929 ms
64 bytes from 192.168.1.1: icmp_seq=1036 ttl=64 time=1.04 ms
64 bytes from 192.168.1.1: icmp_seq=1037 ttl=64 time=0.990 ms
ping: sendmsg: Network is unreachable
iwconfig
wlan0     IEEE 802.11bgn  ESSID:"o2-WLAN38"  Nickname:"<WIFI@REALTEK>"
      Mode:Managed  Frequency:2.467 GHz  Access Point: 9C:80:DF:4C:35:14
      Bit Rate:150 Mb/s   Sensitivity:0/0
      Retry:off   RTS thr:off   Fragment thr:off
      Power Management:off
      Link Quality=90/100  Signal level=100/100  Noise level=0/100
      Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
      Tx excessive retries:0  Invalid misc:0   Missed beacon:0
ifconfig -a
wlan0     Link encap:Ethernet  HWaddr 74:da:38:5b:66:65
      inet addr:192.168.1.65  Bcast:192.168.1.255  Mask:255.255.255.0
      inet6 addr: fe80::76da:38ff:fe5b:6665/64 Scope:Link
      UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
      RX packets:174 errors:0 dropped:26 overruns:0 frame:0
      TX packets:436 errors:0 dropped:1 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:367880 (359.2 KiB)  TX bytes:277624 (271.1 KiB)
sudo route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.1.1     0.0.0.0         UG    303    0        0 wlan0
192.168.1.0     0.0.0.0         255.255.255.0   U     303    0        0 wlan0
syslog (at 22:16:57 the connection gets lost and I can neither load websites, ping the router etc.)
Feb  2 22:04:12 raspberrypi dhcpcd[527]: wlan0: Router Advertisement from fe80::1
Feb  2 22:08:07 raspberrypi dhcpcd[527]: wlan0: Router Advertisement from fe80::1
Feb  2 22:08:11 raspberrypi dhcpcd[527]: wlan0: Router Advertisement from fe80::1
Feb  2 22:08:15 raspberrypi dhcpcd[527]: wlan0: Router Advertisement from fe80::1
Feb  2 22:13:47 raspberrypi dhcpcd[527]: wlan0: Router Advertisement from fe80::1
Feb  2 22:14:04 raspberrypi systemd[1]: Starting Cleanup of Temporary Directories...
Feb  2 22:14:04 raspberrypi systemd[1]: Started Cleanup of Temporary Directories.
Feb  2 22:16:57 raspberrypi dhcpcd[527]: wlan0: carrier lost
Feb  2 22:16:57 raspberrypi wpa_supplicant[357]: wlan0: CTRL-EVENT-DISCONNECTED bssid=9c:80:df:4c:35:14 reason=0
Feb  2 22:16:58 raspberrypi avahi-daemon[515]: Withdrawing address record for 192.168.1.65 on wlan0.
Feb  2 22:16:58 raspberrypi avahi-daemon[515]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.65.
Feb  2 22:16:58 raspberrypi avahi-daemon[515]: Interface wlan0.IPv4 no longer relevant for mDNS.
Feb  2 22:16:58 raspberrypi dhcpcd[527]: wlan0: deleting route to 192.168.1.0/24
Feb  2 22:16:58 raspberrypi dhcpcd[527]: wlan0: deleting default route via 192.168.1.1
Feb  2 22:16:59 raspberrypi wpa_supplicant[357]: wlan0: Trying to associate with 9c:80:df:4c:35:14 (SSID='o2-WLAN38' freq=2467 MHz)
Feb  2 22:16:59 raspberrypi wpa_supplicant[357]: wlan0: Association request to the driver failed
Feb  2 22:16:59 raspberrypi wpa_supplicant[357]: wlan0: Associated with 9c:80:df:4c:35:14
Feb  2 22:16:59 raspberrypi wpa_supplicant[357]: wlan0: WPA: Key negotiation completed with 9c:80:df:4c:35:14 [PTK=CCMP GTK=TKIP]
Feb  2 22:16:59 raspberrypi wpa_supplicant[357]: wlan0: CTRL-EVENT-CONNECTED - Connection to 9c:80:df:4c:35:14 completed [id=0 id_str=]
Feb  2 22:16:59 raspberrypi dhcpcd[527]: wlan0: carrier acquired
Feb  2 22:16:59 raspberrypi dhcpcd[527]: wlan0: IAID 38:5b:66:65
Feb  2 22:16:59 raspberrypi dhcpcd[527]: wlan0: rebinding lease of 192.168.1.65
Feb  2 22:16:59 raspberrypi dhcpcd[527]: wlan0: soliciting an IPv6 router
Feb  2 22:17:00 raspberrypi dhcpcd[527]: wlan0: Router Advertisement from fe80::1
Feb  2 22:17:01 raspberrypi ntpd[616]: Deleting interface #3 wlan0, 192.168.1.65#123, interface stats: received=93, sent=95, dropped=0, active_time=1071 secs
Feb  2 22:17:01 raspberrypi ntpd[616]: 144.76.117.245 interface 192.168.1.65 -> (none)
Feb  2 22:17:01 raspberrypi ntpd[616]: 144.76.14.132 interface 192.168.1.65 -> (none)
Feb  2 22:17:01 raspberrypi ntpd[616]: 217.79.179.106 interface 192.168.1.65 -> (none)
Feb  2 22:17:01 raspberrypi ntpd[616]: 78.46.53.8 interface 192.168.1.65 -> (none)
Feb  2 22:17:01 raspberrypi ntpd[616]: peers refreshed
Feb  2 22:17:01 raspberrypi CRON[1327]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Feb  2 22:17:04 raspberrypi dhcpcd[527]: wlan0: leased 192.168.1.65 for 604800 seconds
Feb  2 22:17:04 raspberrypi dhcpcd[527]: wlan0: adding route to 192.168.1.0/24
Feb  2 22:17:04 raspberrypi dhcpcd[527]: wlan0: adding default route via 192.168.1.1
Feb  2 22:17:04 raspberrypi rsyslogd-2007: action 'action 17' suspended, next retry is Tue Feb  2 22:17:34 2016 [try http://www.rsyslog.com/e/2007 ]
Feb  2 22:17:04 raspberrypi avahi-daemon[515]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.65.
Feb  2 22:17:04 raspberrypi avahi-daemon[515]: New relevant interface wlan0.IPv4 for mDNS.
Feb  2 22:17:04 raspberrypi avahi-daemon[515]: Registering new address record for 192.168.1.65 on wlan0.IPv4.
Feb  2 22:17:06 raspberrypi ntpd[616]: Listen normally on 6 wlan0 192.168.1.65 UDP 123
Feb  2 22:17:06 raspberrypi ntpd[616]: peers refreshed
Feb  2 22:17:09 raspberrypi dhcpcd[527]: wlan0: carrier lost
HybridPepper
WiFi by its nature goes up and down, but normally reconnects automatically.
Unfortunately you have disabled the software which would do this by the changes you have made to the configuration files.
With the settings as listed I am amazed that it worked at all.
The tutorial https://raspberrypi.stackexchange.com/a/37921/8697 shows the correct contents of these files and how it should be configured.
I found this to be a peripheral power problem. If you are trying to power too many USB devices, you want to get a self powered USB hub to get enough power to everything. I found pluging the wifi dongle directly to the Pi and the other keyboard/mouse and other stuff into the hub works very well. Hope this helps.
energyi
As stated in this document : https://dontpressthat.wordpress.com/2017/11/03/prevent-raspberry-pi-dropping-wifi/
When you see "carrier lost" in your sys log after pi losing wifi connection, it may be caused by power saving, the fix from the document is to disable the power saving mode :
sudo iw wlan0 set power_save off
and to disable power saving automaticly on start up, add following lines to /etc/rc.local:
/sbin/iw dev wlan0 set power_save off
Lin Xuhao
