I got a Raspberry Pi 2 and it did not work with the newest version of NOOBS (flashing LEDs). There is nothing on the TV/monitor. It just says there is no HDMI input. I tried it with an older version and the lights stopped flashing, but still the same problem with the video output. I tried re-installing and re-formatting the OS and SD card multiple times with no luck. I tried multiple different power supplies with sufficient amperage, and multiple TVs. Still dose not work. I ended up returning the Pi and got a new one. I am getting the same problem the the new one.
Ghanima
  • 15,958
  • 65
2024: An up-to-date version of this is now maintained at https://www.raspberrypi.com/documentation/computers/configuration.html#led-warning-flash-codes
Based on the type of flashing of the green (ACT) LED, you can figure out what is wrong (or at least what ballpark it's in) by looking at [this page] 1.
Too long didn't read version:
Green LED: ACT LED ------ Red LED: PWR LED
Simple Issues
  • No PWR LED - No power.
  • PWR LED Blinking - Not enough power.
  • PWR LED but no ACT LED (For Pi 1s) - Problem with SD card.
  • PWR LED on ACT LED on and STEADY (For Pi 2) - Problem with SD card.
ACT LED Flashing in Specific Pattern
  • 1 flash - OS too old. FIX: Use OS written after September 2013
  • 2 flashes - SD Card cannot be read.
FOR SOFTWARE (OSs) BEFORE OCTOBER 2012:
  • 3 flashes - loader.bin not found
  • 4 flashes - loader.bin not launched
  • 5 flashes - start.elf not found
  • 6 flashes - start.elf not launched
  • 7 flashes - kernel.img not found
FOR SOFTWARE (OSs) AFTER OCTOBER 2012:
  • 3 flashes - start.elf not found
  • 4 flashes - start.elf not launched
  • 8 flashes - SDRAM not recognised. FIX: Newer bootcode.bin/start.elf firmware.
Patrick Cook
  • 6,365
  • 38
  • 63
Try booting the board with your hdmi plugged in and without a sd card. One should see the test rainbow screen. If not then there is a malfunction either in your display, cable, and/or the raspberry pi.
