9
I just got my Raspberry Pi in the mail, and went to hook it up to my TV with an HDMI cable. I plugged in the cable (known to work with my cable box), a keyboard, and then power. A light comes on the Raspberry Pi, but no picture.
Is there something special I need to do first? I have the OS on a flash card already and it's inserted.
I found a TV with RCA input, that I was able to hook it up with. I know the OS is fine, and went through the configuration wizard. Unfortunately, I don't see anything on the HDMI side yet.
syb0rg
  • 8,178
  • 38
Canadian Luke
  • 520
11 Answers11
13
I had a similar problem with my Pi, when I connected it first time to my tv (a Samsung D5000): the tv did not understand an HDMI device was connected. I have raspbmc as the os.
There are a couple of instructions you can add to /boot/config.txt to tell your Pi to activate the hdmi output when you connect a cable, and to force hdmi output mode instead of dvi. I added these lines, rebooted Pi, and began seeing my raspberry on screen :)
config_hdmi_boost=4
hdmi_force_hotplug=1
hdmi_drive=2
Reference: How do I force the Raspberry Pi to turn on HDMI?
Trapias
  • 146
In config.txt
comment out
#dtoverlay=vc4-fkms-v3d
this started my system to work. I think only one hdmi output works but I do not care. It has a problem finding which video to use and some people have it start working on its own.
Ghanima
  • 15,958
  • 65
john
@Trapias's answer is correct.
Another alternative is to uncomment the line
# hdmi_safe = 1
in the config.txt file.
You should also verify the correct operation of the screen, the cable and the Raspberry.
Greenonline
  • 2,969
  • 38
sudo tvservice -p
will turn on HDMI output if it was disabled for some reason. Check out the other options of this command.
Raphael
  • 576
I was getting this problem I took out the sd card put it back in again and then turned it on(pluged in the power ) and it worked!
Valente
I think that's DVI not HDMI. I know that in datasheet it says HDMI. I'm using an HDMI to DVI cable to get the image on the screen.
Adrian
  • 75
Ensure that the connections are all secure.
Carefully, but surely, do this. First-time connections can be difficult. If you push too hard, you may damage the unit. If you don't push hard enough, you may not have a good connection.
Ensure the SD Card is not placed upside-down. (It happens.)
Try re-flashing the operating system to the SD Card.
Good luck and let us know of any updates.
Zéychin
  • 111
I just went through the whole ordeal and I finally went to the little user manual. It says in simpleton - plug everything in and have the TV on but plug the power last. "Everything" meant: HDMI; keyboard; mouse, and; the micro SD card. Now the last thing that you will plug in is the POWER. This will send the PI to boot. If you do this in a different sequence in the initial power up, it will not work. POWER has to be last thing, after everything necessary has been plugged in.
Greenonline
  • 2,969
  • 38
arri
It had been a while since using my raspberry pi and when I turned it on, the system booted up fine showing the splash screen. After the system booted and I saw the background for a split second,the screen went blank. Thr screen remained blank unless I moved my mouse. The video only displayed in raspbian while moving the mouse after boot. I held shift at boot for recovery and reran install. Problem fixed. No more video issues. This was raspbisn 1.2 as that was the version that came with my device
I tried everything you all suggested without success. Hope this helps someone.
Putting config_hdmi_boost to 9 helped for my old SONY KDL-46W5500m
-4
Download the torrent for the os not the zip. You can also try to wiggle the power cable because it might not have enough power
Hayden
