I changed my Raspberry Pi keyboard (using command the sudo nano /etc/default/keyboardp). I set:
XKBLAYOUT = 'in'
Now, after reboot I just can't login! Can I somehow reset this CHANGE?
Can you insert the SD card into another machine and mount the filesystem?
If so, edit /etc/default/keyboard and change XKBLAYOUT="in" back to your desired setting.
If needed, there's a list of valid codes on Wikipedia.
If you know the IP address you can ssh from another machine. Then use the raspi-config utility:
Open a terminal
raspi-configLocalisation OptionsChange Keyboard LayoutEnglish (US)sudo rebootAlternatively to ssh, if you have proper partitions on your SD card you can:
vim /Volumes/<card name>/etc/default/keyboard to XKBLAYOUT="in" to XKBLAYOUT="us" or whatever suits your needYou have switched to an Indic keyboard, though it's hard to know which one. They look quite different depending on which one was selected. There are some examples here: http://wiki.laptop.org/go/Keyboard_layouts#Indic
You basically have two choices: use another machine to ssh into you pi and fix it, or reflash your pi and start over.
