Per Boot from external USB stick / drive? - Raspberry Pi Stack Exchange: I am able to mount my USB stick within OS (/dev/sda1), I then replaced root='s value with /dev/sda1 inside of cmdline.txt from boot sdcard (rootwait is already there), yet kernel panics while booting with message:
Unable to mount root fs on unknown-block(8,1)
* UPDATE *
cmdline.txt (modified & unmodified (respectively)):
alexus@rpi2:/mnt$ cat cmdline.txt
dwc_otg.lpm_enable=0 console=tty1 root=/dev/sda1 rootfstype=ext4 elevator=deadline rootwait quiet splash
alexus@rpi2:/mnt$ cat cmdline.bak
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait quiet splash
alexus@rpi2:/mnt$
/etc/fstab (original line is commented out & additional line with UUID):
alexus@rpi2:~/Desktop$ cat /etc/fstab
proc            /proc           proc    defaults          0       0
#/dev/mmcblk0p2  /               ext4   defaults,noatime  0       1
UUID=AB6A-1DFE  /               ext4   defaults,noatime  0       1
/dev/mmcblk0p1  /boot/          vfat    defaults          0       2
output from findmnt:
alexus@rpi2:~/Desktop$ findmnt
TARGET                           SOURCE         FSTYPE          OPTIONS
/                                /dev/mmcblk0p2 ext4            rw,noatime,data=ordered
├─/dev                           devtmpfs       devtmpfs        rw,relatime,size=469760k,nr_inodes=117440,mode=755
│ ├─/dev/shm                     tmpfs          tmpfs           rw,nosuid,nodev
│ ├─/dev/pts                     devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
│ └─/dev/mqueue                  mqueue         mqueue          rw,relatime
├─/sys                           sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
│ ├─/sys/fs/cgroup               tmpfs          tmpfs           ro,nosuid,nodev,noexec,mode=755
│ │ ├─/sys/fs/cgroup/systemd     cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd
│ │ ├─/sys/fs/cgroup/cpuset      cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,cpuset,clone_children
│ │ ├─/sys/fs/cgroup/devices     cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,devices
│ │ ├─/sys/fs/cgroup/freezer     cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,freezer
│ │ ├─/sys/fs/cgroup/net_cls     cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,net_cls
│ │ ├─/sys/fs/cgroup/blkio       cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,blkio
│ │ └─/sys/fs/cgroup/cpu,cpuacct cgroup         cgroup          rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
│ ├─/sys/kernel/debug            debugfs        debugfs         rw,relatime
│ │ └─/sys/kernel/debug/tracing  tracefs        tracefs         rw,relatime
│ ├─/sys/kernel/config           configfs       configfs        rw,relatime
│ └─/sys/fs/fuse/connections     fusectl        fusectl         rw,relatime
├─/proc                          proc           proc            rw,relatime
│ └─/proc/sys/fs/binfmt_misc     systemd-1      autofs          rw,relatime,fd=23,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
├─/run                           tmpfs          tmpfs           rw,nosuid,nodev,mode=755
│ ├─/run/lock                    tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
│ └─/run/user/1000               tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=94816k,mode=700,uid=1000,gid=1000
│   └─/run/user/1000/gvfs        gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
├─/boot                          /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
└─/media/alexus/LEXAR128G        /dev/sda2      vfat            rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro
alexus
  • 337
  • 25
The image you are trying to mount needs to have the /etc/fstab modified to match the mountpoint. The most reliable method is to use a UUID.
EDIT 2016-01-14
You seem to make things difficult for yourself. The first step is to boot from SD with the new HD, make sure everything is OK then make changes.
I assumed you would leave the fstab entry for the HD, although obviously you should mount somewhere else e.g. /mnt/hdroot (invent a name that means something to you). This lets you check the UUID and easily modify the fstab in /mnt/hdroot/etc.
The UUID looks strange, normally this would be a 128 bit value.
/dev/mmcblk0p1 /boot/ looks unusual this would normally be /boot.
You seem to have a vfat partition on /dev/sda2 mounted in /media I guess this is an auto mount in GUI.
