I have installed Raspbian using Noobs.
I need to set a static ip address.
The config files on my Pi bears not relation the articles I can find on the internet.
Can anyone point me to a good article or advise me of the settings.
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
allow-hotplug wlan1
iface wlan1 inet manual
Thanks for reading.
Mesogi
  • 101
It might be easier to get the mac address of the device (eg. 1), then assign one using your router (2). This avoids having to dig through config files as long as you have router admin access!
This article seems to be pretty detailed and shows exactly what you need to do:
In summary, do:
sudo nano /etc/network/interfaces
Change:
iface eth0 inet dhcp
TO
iface eth0 inet static
Add:
address <desired_ip>
netmask <run ifconfig -> Mask field>
network <run netstat -> Destination>
broadcast <run ifconfig -> Bcast field>
gateway <run netstat -nr - look for gateway>
then
sudo rm /var/lib/dhcp/*
sudo reboot
To check: ifconfig and make sure you get that ip.
