So, I've ran arp -a in raspberry pi and it shows some addresses:
    ? (10.50.220.1) at 00:14:a9:d0:72:80 [ether] on wlan0
    ? (10.50.221.198) at 48:5a:b6:6d:07:ef [ether] on wlan0
    ? (10.42.0.1) at 5c:f9:dd:3f:f9:27 [ether] on eth0
    ? (10.50.220.250) at 70:18:8b:0e:a2:71 [ether] on wlan0
If I try to ping any of those addresses, it works. If I try to ssh, it fails. Also, I tried ifconfig wlan0, which returns a ip address that doesn't exist:
wlan0     Link encap:Ethernet  HWaddr 74:da:38:5c:7b:01
          inet addr:10.50.221.13  Bcast:10.50.223.255  Mask:255.255.252.0
          inet6 addr: fe80::76da:38ff:fe5c:7b01/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:3319 errors:0 dropped:1 overruns:0 frame:0
          TX packets:710 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:373186 (364.4 KiB)  TX bytes:79057 (77.2 KiB)
When I try to ping ip address 10.50.221.13 from another terminal it fails:
PING 10.50.221.13 (10.50.221.13) 56(84) bytes of data.
From 10.50.221.249 icmp_seq=1 Destination Host Unreachable
From 10.50.221.249 icmp_seq=2 Destination Host Unreachable
From 10.50.221.249 icmp_seq=3 Destination Host Unreachable
From 10.50.221.249 icmp_seq=4 Destination Host Unreachable
From 10.50.221.249 icmp_seq=5 Destination Host Unreachable
From 10.50.221.249 icmp_seq=6 Destination Host Unreachable
^C
--- 10.50.221.13 ping statistics ---
7 packets transmitted, 0 received, +6 errors, 100% packet loss, time 6029ms
pipe 3
Here is the output of /etc/network/interfaces:
interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
iface eth0 inet dhcp
# The wifi (wireless) network interface
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
     wpa-ssid "optix"
     wpa-psk "XXXX"
When I use the app Fing on my phone, it doesn't show that ip address either.
The Raspberry Pi has a Edimax N150 Wi-Fi Nano USB Adapter on it. I only have managed to connect via an ethernet cable.
This may not be the same as other questions, as far as I can tell.
SlySven
  • 3,631
  • 46
user3273814
  • 182
This is because WLAN is in different subnet than ETH...
Check your wifi ip and netmask:
10.50.221.13 / 255.255.252.0
That subnet doesn't contain the ethernet ip address: 10.42.0.1.
In fact, because of that mask, your wlan subnet contains ips:
10.50.220.1 to 10.50.223.254 or something like that (same count of ips).
You can check out this tool, if you don't know anything about netmasks.
How to fix that? Well... The easiest way would be to setup wifi router, so it would assign adresses from same subnet (10.42.x.), not (10.50.x.), for example:
10.42.0.128 - 10.42.0.254
and ethernet to
10.42.0.1 - 10.42.0.127
or simply change ethernet ip, so it would be in range:
Flash Thunder
  • 335
